Thread: Tie Rod End Replacement
Results 1 to 4 of 4
  1. #1 Tie Rod End Replacement
    Sep 2012
    Cedar Rapids, Iowa
    Anyone have some general instructions on how to replace the front driver's side tie rod end? I've replaced the CV axle, struts, wheel hub/bearing and brakes. Never touched one of these though and I'm not exactly sure how it goes.
  2. #2 Re: Tie Rod End Replacement
    Using whatever size large wrench, loosen the nut that locks the end to the tie rod. All you need to do is loosen 1/4 turn or so to unlock. Don't spin it all the way back.
    Remove cotter from tie rod end at knuckle if one exists. Remove tie rod end nut. Remove end from knuckle (usually a hammer hit frees it), now spin the old tie rod end off, counting the turns.
    Put new end on the same number of turns, put it into knuckle and if needed hit it down to seat it and get the nut on with new cotter. Tighten nut on rod to end to lock it in place.
    Get alignment.
  3. #3 Re: Tie Rod End Replacement
    Jun 2013
    N/A
    Get alignment.
    I can never beat you to it. lol
  4. #4 Re: Tie Rod End Replacement
    I tend to type fast???
  1. BMC replacement?
    By talltree in forum 04+ Specifics
    Last Post: 02-27-2014, 06:21 AM
  2. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  3. 02' GP GT LIM/UIM Replacement
    By 02GPinNY in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2013, 08:32 AM
  4. Amp replacement
    By whatthekrapp in forum Audio, Security & Visual Electronics
    Last Post: 01-12-2013, 09:43 AM
