Thread: Gtp checklist what do you all think?
Results 1 to 10 of 10
  1. #1 Gtp checklist what do you all think?
    Sep 2011
    Omaha
    I'm posting up suspension check list here to see what you all think of it or if there is something I've missed or is a better option! If anyone has input It would be greatly appreciated!! Last one about my suspension I promise! I just want to do it right!!
    04 Grand Prix FTP overhaul (non comp g)
    -KYB struts
    -Monroe mounts
    -Comp g springs (can't seem to find where to buy these new anyone have a link please?)
    -2x Moog control arm (ball joint is out might as well do it all)
    -2x trailing arms, not sure on brand but probably Moog?
    -Swaybar end links Moog
    -Anti-pogo's (zzz) probably not necessary but might as well
    -Engine & Trans mounts
    -Strut boots
    ----not sure on this, will I need rear lower spring idolaters? & front upper&lower spring isolates?? If so what brand is preferred?----
    I'm pretty sure that is everything I have so far! I think it is complete but please take a look and tell me if there is anything ive missed or anything you would recommend instead! Thank you!
    3.5 in" pulley, zzp dp, custom hai, colder plugs, red wires- red means fast, Tog headers, resonater Delete, custom dyno tuned and max out injectors...
  2. #2 Re: Gtp checklist what do you all think?
    Ocala, FL
    If your strut boots aren't torn, I wouldn't replace them.
    Your stock ones might be dirty(so they're doing their job), but the aftermarket ones are not as sturdy, and will eventually rip/tear.
    I believe Dorman would be a good pick for trailing arms, they're tubular, not like the stamped u channel stockers.
  3. #3 Re: Gtp checklist what do you all think?
    Banned
    You should get GM mounts for the trans and motor. They feel WAY better than anything from the parts store.
  4. #4 Re: Gtp checklist what do you all think?
    Sep 2011
    Omaha
    Quote Originally Posted by ebk231 View Post
    Are you just talking about parts store as in OEM ones? And I will definitely check them out!
  5. #5 Re: Gtp checklist what do you all think?
    Sep 2011
    Omaha
    Quote Originally Posted by codyAK View Post
    Thank you for the info on the boots! Saved me $$ and then some in the long run! So Dorman is less expensive and a better part? Or is it just for trailing arms?
  6. #6 Re: Gtp checklist what do you all think?
    Banned
    No Im talking actual GM part #'s from gmpartnow, amazon , or what ever site you choose. They cost more, but it is money well spent in my opinion. I have had a couple different mount setups and went back to all brand new GM mounts and the car feels fantastic.
  7. #7 Re: Gtp checklist what do you all think?
    Sep 2011
    Omaha
    Gotcha so on rockauto is it just a acdelco?
    Will GXP springs raise the height of kyb struts on a 04?
  8. #8 Re: Gtp checklist what do you all think?
    Sep 2011
    Omaha
    Will GXP springs raise the height of my 04 gtp with kyb struts?
  9. #9 Re: Gtp checklist what do you all think?
    Banned
    I believe all 04+ springs are the exact same.
    Here is part #'s for GM mounts, I have not been able to find AC delco mounts. You can search for them on ebay or amazon if you want a better price. I thought GMpartsnow was fair, and you can get them all at once
    Lower engine - #10448575
    Lower trans -#22146834
    Upper engine bracket -#22146834 (x2)
    Dog bone/engine strut -#10230877 (x2)
    Like I said it cost more, but its worth it if you want a smooth feeling car. Plus the autostore versions tend to wear quickly.
  10. #10 Re: Gtp checklist what do you all think?
    Sep 2011
    Omaha
    What about the wbodystores 6piece mount kit? Does shortened dog bones do anything if you're not lowered?
  1. New to me car checklist
    By GTPgasm in forum General Grand Prix Discussion
    Last Post: 03-15-2014, 07:29 AM
  2. LIM Job Checklist
    By Dr Cedric in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2013, 11:31 PM
  3. Anyone recomend a checklist for over 100k miles?
    By chrisatpsu in forum General Tech Discussion
    Last Post: 05-21-2012, 01:35 AM
  4. Suspension overhaul checklist
    By RareGMFan in forum Brakes/Suspension/Chassis
    Last Post: 12-02-2010, 10:58 AM
  5. new pistons: going down the checklist
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 05:37 PM
