i was wondering if the front brake caliper, braket, and rotor can be put on the back for rear brakes? thanks for your input.
No they can't
and by research, he means there's jack crap for the rears. They're borderline irrelevant anyway. just do some nice pads and call it good.
Unless you're lowered and rocking stiffer struts don't bother.
But if you are....
GXP rear brakes.
And you would never want to run the front brakes on the rear unless the suspension was rock solid, even then, you'd still want more brake bias towards the front.
would you need the whole set-up?, like all the lines and parking brake stuff or just the caliper and the mounting bracket?
I'm not going to answer that one since theres a brake sticky that should cover this.
you have discs and drums in the rear. the parking brake uses drums so therefore you can not put this in the back period! just look in to the 12'' brake upgrade thread i belive there is something there for the rear too!.
I think he was trying to say we have a drum in hat ebrake.
Drummin Hat???
You were very unclear.
