Thread: HELLPPP!!! 15 mpg
Results 1 to 15 of 15
  1. #1 HELLPPP!!! 15 mpg
    Donating Users
    Plainfield, IL
    so my avg mpg is 15.5 wtf is that im only ruuning intake and headers and colder plugs gapped at .55 could having colder plugs and a smaller gap ccause this small of a increase in fuel consumption???
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: 15 mpg
    you shouldnt be running colder plugs on a stock car anyway, but it sounds like more than that. like an o2 sensor or something of the like.
  3. #3 Re: 15 mpg
    Donating Users
    Plainfield, IL
    i just replaced the narrow band o2 and im catless so the 2nd one is unplugged....i remote start my car alot and it sits and idles could that be it because my aeroforce reads an average mpg of 21
  4. #4 Re: 15 mpg
    Donating Users
    Plainfield, IL
    i also with the aeroforce accidently reset my fuel trim....would that mess anything up? i also accidently ended up stuck doing a case learn awhile back because i selected it lemme know if either of those could be the culprit...
  5. #5 Re: 15 mpg
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    Quote Originally Posted by gotboost3 View Post
    yes, My remote start kills my MPG! and having your o2 just unplugged doesent help. get a o2 delete ZZ Performance
  6. #6 Re: HELLPPP!!! 15 mpg
    CT
    ??? You don't have a cat and have the rear 02 unplugged ??? do you have a tune to account for this
  7. #7 Re: HELLPPP!!! 15 mpg
    Donating Users
    Plainfield, IL
    no sir i do not could that be my problem lol
  8. #8 Re: HELLPPP!!! 15 mpg
    Aug 2008
    Long Island, New York
    my car reads 15ish on the DIC alot, but i think its just because i start my car up every mrning and idle it for 15 minutes before driving.
  9. #9 Re: HELLPPP!!! 15 mpg
    Feb 2009
    Red Deer AB
    Or, a programmed pcm with the o2 delete
  10. #10 Re: HELLPPP!!! 15 mpg
    GTP Level Member dstout's Avatar
    ky
    So....How long does an o2 Sensor usually last or should I ask how do you know it's bad without scanning?
    I have a replacement front o2 that I have thought about changing since the original is about 6 years old but I dont know if it needs it or not as I'm pretty much stock.
  11. #11 Re: HELLPPP!!! 15 mpg
  12. #12 Re: HELLPPP!!! 15 mpg
    Jul 2008
    Germantown, Maryland
    so if i delete my rear 02 code then I have no need for the O2 emulator, right?
  13. #13 Re: HELLPPP!!! 15 mpg
    Feb 2009
    Red Deer AB
    Quote Originally Posted by Quicklynx View Post
    if by delete you mean on your pcm then yes. you wont need the o2 delete
  14. #14 Re: HELLPPP!!! 15 mpg
    Donating Users
    Plainfield, IL
    yeah i figured it was the remote start and idleing kills MPG's weird thing is i plugged the rear o2 back up and tucked it away and i now have no ses light and i gained a few mpg's
  15. #15 Re: HELLPPP!!! 15 mpg
    Jul 2008
    yea, i can delete it with my HP Tuners... Thanks!
