Thread: Bent caliper bracket slide pin recommendations
Results 1 to 20 of 21
  1. #1 Re: Bent caliper bracket slide pin recommendations
    why bother using a single piston caliper for a up grade? f bodys are dual piston.
    every thing zzp sells is the same thing you can go buy off the shelf at your parts store. if you know what car they came off of originally.
    What you bought wasn't much of a upgrade. Should of went fbodies and be done with it.
    04 Comp G.
  2. #2 Re: Bent caliper bracket slide pin recommendations
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    Ok, reread, Scottydoggs' about everything being off the shelf. I'm not sure it's always that simple, but I'll start there.
    It's my DD, & only car, & I do the work alone. The only real way to know, is to try & put them on. Brakes are not hard to me, just a pita b/c if something goes wrong, I can be stuck w/o wheels until I get someone to help bleed them. Always better I if know before I put it on jacks.
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  3. #3 Re: Bent caliper bracket slide pin recommendations
    Quote Originally Posted by Mr D View Post
    trust me, zzp dont make them calipers or the brackets. the F bodys are on any, and i mean any, v6, ss or any other type of 98-02 camaro or firebird you see on the road, or junk yard. nothing that should command what those asshats charge for some stuff.
    f bodys clear 16 wheels too. aka stock wheels. i got em, under stock 16 inch caddy wheels.
    as far as bleeding the brakes, make a one man bleeder. you get some clear tubing that fits the nipple on the caliper bleeder, run the tube through a hole in a cap of a bottle then to the very bottom of the bottle. then make another hole in the cap for a vent. then add a few inches of new clean brake fluid, then open the bleeder, now slowly push the brake pedal 3 or 4 times, then go look at the line, if theres a air bubble in the clear line, push the pedal a few more times. repeat for all calipers.
    make sure the master dont run dry.
  1. Rubbing on the Caliper Bracket???
    By CameronMRich in forum Tires & Wheels
    Last Post: 03-22-2014, 03:56 PM
  2. Brake caliper slide pin?
    By Fahrenheit in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2012, 12:21 PM
  3. F body caliper bracket?
    By kevins in forum Brakes/Suspension/Chassis
    Last Post: 10-30-2012, 03:54 PM
  4. caliper bracket
    Last Post: 08-16-2009, 02:04 PM
  5. caliper bracket
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 08:44 PM
