Thread: Rear caliper rebuild or replace?
Results 1 to 5 of 5
  1. #1 Rear caliper rebuild or replace?
    GTP Level Member
    Aug 2012
    st louis park, MN
    Guys and gals,
    I have noticed my rear calipers are leaking from around the e-brake spring/seal and covering everything back there in brake fluid. My general question is what is the level of effort in doing a rebuild kit vs buying a whole assembled caliper? I would be happy to do the rebuild since its 10x cheaper but if the rebuild itself is finicky I'd be fine spending the extra and having all new equipment back there. I'm in MN so things were a bit crusty back there - probably nothing some cleaning wouldn't resolve.
    Anyone care to pitch in opinions? I really don't want to do the rebuilt and end up with a leak thinking why the f didn't I just buy the new assembly?!
    Thanks!
  2. #2 Re: Rear caliper rebuild or replace?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    have you looked at how cheap remans are?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: Rear caliper rebuild or replace?
    Enfield, CT
    Depends. do you have access to a quality sand blaster? An oven? Jet wash? If not, you can tear down the caliper itself and give the caliper with the bracket to a machine shop and they'll do a great job cleaning it up. But that's at a cost and getting new bolts, bleeders, boots, seals are additional cost to the rebuild which come pretty close to a reman hence why most people go with remans. Also remans have warranties.
  4. #4 Re: Rear caliper rebuild or replace?
    I break stuff selliott's Avatar
    Kansas City
    I agree just do a reman save your time and headache
  5. #5 Re: Rear caliper rebuild or replace?
    GTP Level Member
    Aug 2012
    st louis park, MN
    Went with remans from Napa. Overall I think it was a good choice compared to refreshing my own - that would have been a nightmare. One of the e brake springs wasn't very tight and the pads would probably drag a bit after I use the e brake. Is this easy to adjust?
  1. caliper rebuild
    By Logan541 in forum General Tech Discussion
    Last Post: 02-10-2013, 11:16 AM
  2. Caliper rebuild question
    Last Post: 10-27-2012, 03:55 PM
  3. Need 13“ caliper rebuild kits but..
    By SDGTP99 in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2012, 03:10 PM
  4. CV Shaft Rebuild/Replace [*]
    By Reptile in forum How To Write-Ups/Tech Tips
    Last Post: 11-06-2009, 02:04 PM
  5. question on Fbody caliper pistons rebuild
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2008, 12:08 PM
