Thread: AGK coilovers, zzp control arms
Results 1 to 20 of 28
  1. #1 Re: AGK coilovers, zzp control arms
    buy a set of BC coilovers for $900 from a car that has a similar suspension, move/modify lower mount as necessary to bolt up to the knuckle, then modify the upper mount to either accept the stock GP mount (rubber mounts bad, no no) or make it so the studs are in the correct spot (hint: make a new top half of the pillow ball mount).
  2. #2 Re: AGK coilovers, zzp control arms
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Considering the coilovers are inserted into the housings basically why hasnt anyone else used something that wont blow out or has a longer stroke to the strut maybe koni or some other brand. Obviously this wouldnt be for the vendor coillvers but the DIY guy i would have thought by now something better than agx would have been used.
    W-body's are dead, no one will develop new struts/suspension for this car now.
    you'd want a shorter overall body, which in turn would have a shorter stroke.
    but "no one has found" a strut that'd work.
    i would personally just buy a set of coilovers that were for another car, then modify the mounting points so they worked.
    I did.
    Koni said they would make custom inserts for my fronts that shortened the overall length 3"...it was around $400-$500
    Been down this road.
    The Nissan Maxima is very close fit up front. From my early measurements anyways. There are a ton of MacPherson strut setup cars out there. The multilink rear is a bit different, but you can buy just the front coilovers from companies if you give them a call.
  3. #3 Re: AGK coilovers, zzp control arms
    SWPA
    Quote Originally Posted by Drunkie View Post
    Doesn't mean anything. The 3000GT/Stealth has been dead since 99 (96 for the Stealth) and there have been several new suspension bits to come out for it, even within the last few years.
  4. #4 Re: AGK coilovers, zzp control arms
    Arizona
    Stealth also had the GTO name in Japan which figures into the huge after market support it had
  1. ZZP Control Arms
    By SomeDudeAtHome in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2014, 11:13 AM
  2. Lower control arms
    By tachasmo in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2014, 10:28 PM
  3. Control arms
    By mthorn11 in forum Brakes/Suspension/Chassis
    Last Post: 03-01-2013, 01:13 PM
  4. Control Arms - Which Ones?
    By SliceTheRice in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2011, 03:52 PM
  5. ZZP control arms
    By Sabrewings in forum Brakes/Suspension/Chassis
    Last Post: 02-20-2009, 11:06 PM
