Thread: clips on rear rotors?!?
Results 1 to 9 of 9
  1. #1 clips on rear rotors?!?
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    I just did my rear brakes today and let me say I got my moneys worth. Lol, metal on metal to the point were my rotors were dug in a good 1/8". Anyway, my rotors were held in by little metal clips that spun on the lugs. I didn't reuse them and don't hear the rotor rattling. Parts store don't have a listing for it. Was it something the last person did as a precaution or do they require them? Thanks
  2. #2 Re: clips on rear rotors?!?
    SWPA
    No clips on my rotors. No idea what their purpose would even be.
  3. #3 Re: clips on rear rotors?!?
    Factory brake rotors have 2-3 metal circle push on type clips on the studs to keep everything inline on the assembly line.
    Just about every single car maker uses them, they are not needed.
  4. #4 Re: clips on rear rotors?!?
    ive sen those spiked ring clips on the studs before too. they hold the rotor on. ive never re used one. ever.
  5. #5 Re: clips on rear rotors?!?
    Feb 2013
    Woodbridge NJ
    As Fivefingerdeathpunch stated they are installed on the assembly line to keep the rotors in place during assembly. That is there intended and only purpose. When replacing the rotor you cut them off and forget them. The wheel keeps the rotor in place in the real world
    Don
    2004 GT1
  6. #6 Re: clips on rear rotors?!?
    Nov 2011
    north bay, ontario
    Thanks guys. I thought it was weird as well, I've never seen that before. Those stock brakes sure lasted awhile. I ordered them from prime choice auto parts. No one could touch their prices. Hopefully I'm happy with em.
  7. #7 Re: clips on rear rotors?!?
    Nov 2011
    north bay, ontario
    Unlike the front rotors the rears had lots of play from side to side. A good 1/2" I'd say. Is this normal? ? I went to the drive thru and when I released my brakes I heard the rotors letting go.
  8. #8 Re: clips on rear rotors?!?
    Dec 2010
    ATL,Georgia
    The rear rotors move while the wheel is mounted???
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  9. #9 Re: clips on rear rotors?!?
    Quote Originally Posted by 08 gp lvr View Post
    is this after the wheel was put back on?
    new pads and rotors will drag some till they break in, or you failed to clean and lube the slider pins.
  1. Drag Reduction Clips, Hawk HPS, and Which Rotors?
    By HighOctaneRacing in forum Introductions/Noob Questions
    Last Post: 11-02-2013, 12:33 AM
  2. Rear bumer push pin clips
    By GXPrunner06 in forum Visual/Body Modifications
    Last Post: 10-30-2013, 09:05 AM
  3. Removing rear rotors
    By Deezul_AwT in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 08:15 PM
  4. Installing rear rotors
    By wipeout48 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 11:25 AM
