Thread: clips on rear rotors?!?
Results 1 to 9 of 9
  1. #1 Re: clips on rear rotors?!?
    SE Level Member 08 gp lvr's Avatar
    Nov 2011
    north bay, ontario
    Unlike the front rotors the rears had lots of play from side to side. A good 1/2" I'd say. Is this normal? ? I went to the drive thru and when I released my brakes I heard the rotors letting go.
  2. #2 Re: clips on rear rotors?!?
    Quote Originally Posted by 08 gp lvr View Post
    is this after the wheel was put back on?
    new pads and rotors will drag some till they break in, or you failed to clean and lube the slider pins.
  1. Drag Reduction Clips, Hawk HPS, and Which Rotors?
    By HighOctaneRacing in forum Introductions/Noob Questions
    Last Post: 11-02-2013, 12:33 AM
  2. Rear bumer push pin clips
    By GXPrunner06 in forum Visual/Body Modifications
    Last Post: 10-30-2013, 09:05 AM
  3. Removing rear rotors
    By Deezul_AwT in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 08:15 PM
  4. Installing rear rotors
    By wipeout48 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 11:25 AM
