Thread: problems with mounting new front struts on my 2002
Results 1 to 5 of 5
  1. #1 problems with mounting new front struts on my 2002
    Apr 2011
    San Antonio TX
    I just bought new Monroe front struts and started to mount them and they are extended 1 inch to far to hookup to the knuckle anybody had this problem ive tried to collapse them and no luck any help out there
  2. #2 Re: problems with mounting new front struts on my 2002
    So you can't get either bolt on the knuckle started??
    The 3 bolts on top are in their holes right?
  3. #3 Re: problems with mounting new front struts on my 2002
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Had that problem with them doing that. Had to stand on the LCA to move it enough to slip the bolts in.
    Sent from my Galaxy Tab 3
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: problems with mounting new front struts on my 2002
    St. Louis
    Just stick a pry bar in the lower control arm and push it down, then slip a bolt in the knuckle/strut. Done.
  5. #5 Re: problems with mounting new front struts on my 2002
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Mine were too long to, just pry down but be sure you put the top bolt in right or you can ruin the bolt and the steering knuckle.
  1. 05 Front Struts
    By jkazam1 in forum Brakes/Suspension/Chassis
    Last Post: 03-29-2013, 03:28 PM
  2. Front Struts
    By GPSims39 in forum Brakes/Suspension/Chassis
    Last Post: 05-14-2009, 08:32 AM
