Thread: Brake pedal stopping half way
Results 1 to 8 of 8
  1. #1 Brake pedal stopping half way
    Oct 2013
    Northeast PA
    Im having this issue where every now and again when I'm going slow If I press the brakes the pedal only goes down about half way and stops hard right there. Then it feels like its hopping a bit against my foot. The car will stll move though. It slows me down a bit but 1st gear still pulls me forward. Another note is it seems to happen more if not always when I have the wheel turned one way or another.
    So I haven't pulled the tires yet to look at the brakes. I just got the car not too long ago and don't drive it much so I haven't messed with anything yet. I'm wondering if the pads are sticking on the pin. Has anyone else had a similar issue? Or any ideas on what could be causing this?
    I'm waiting for the insane cold to break a bit so I can get out there and pull the tires so I figured I'd ask you guys.
    Thanks
  2. #2 Re: Brake pedal stopping half way
    Feb 2013
    37.295091, -121.930053
    you may have air in your brake lines. air will cause the pedel to go half way and will not hold you at a stop. bleed them asap
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Brake pedal stopping half way
    Oct 2013
    Northeast PA
    The thing that makes me think that it's not air is the mechanical nature of how it happens. Its a very grindy hard jumpy thing..not the brake going all the way to the floor and not stopping. And every other time it stops great. In fact It stops better than any car I've ever owned.
    Thanks for the reply though. I do need to go over the whole car closely still.
  4. #4 Re: Brake pedal stopping half way
    Nov 2012
    Madison
    Grand Prix ABS....totally ripped
  5. #5 Re: Brake pedal stopping half way
    Jun 2012
    Ontario Canada
    thats your abs, same thing happens to me on ice/snow. is this happening on flat ground? maybe your abs is acting up.
  6. #6 Re: Brake pedal stopping half way
    Oct 2013
    Northeast PA
    It happens on flat ground yes. I think you guys are right about the ABS acting up. It seems like the ABS is engaging at the wrong time.
  7. #7 Re: Brake pedal stopping half way
    the abs light come on when it does this? if so get it scanned for abs codes at a garage.
  8. #8 Re: Brake pedal stopping half way
    Oct 2013
    Northeast PA
    I haven't noticed the ABS light coming on. Usually when it happens I have to be quick about pumping the brake and turning to try to make sure I don't hit anything if the brake pump doesn't work. So far it has worked everytime. I have a friend at Advanced i'll have to get him to hook up the scanner to it.
  1. Brake pedal issues..
    By Bluemagic in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2012, 08:18 PM
  2. brake pedal goes to the floor
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-01-2011, 01:42 PM
  3. brake pedal very soft
    By Jenco in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2010, 07:38 AM
  4. Very stiff brake pedal?
    By Mesaman4 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2010, 05:37 PM
  5. low brake pedal
    By johnk in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2009, 07:58 PM
