Thread: Still clunks after changing front sway bar end links 3 times...
Results 1 to 6 of 6
  1. #1 Still clunks after changing front sway bar end links 3 times...
    SE Level Member sgtmac's Avatar
    Jun 2012
    Illinois
    I have been rebuilding my 2004 GT to last another 200k-replaced the front and rear sway bar bushings with urethane, all struts and end links, new LCA's with ball joints, both front hubs, all brake components, and yet, a clunking over bumps keeps coming back. I believe it to be the front sway bar links. I have replaced the factory ones with the two different Autozone ones(one has Zerk fittings, one doesn't) and now have replaced the Autozone ones with O'Reilly's greaseable ones and still the clunk comes right back. It seems to me that the front links are very long and possibly that is causing premature failure but I haven't got more than 3 months out of a set before the clunking noise comes back. This also happened before the urethane sway bar bushings were installed, too. The greaseable links were much heavier built than the non-greaseable ones but the noise that started up again seems to be the same. Any thoughts?
    Thanks.
    Still clunks after changing front sway bar end links 3 times... Attached Images
  2. #2 Re: Still clunks after changing front sway bar end links 3 times...
    check the strut mounts?
    is your car lowered? i cant see end links blowing gout in a few months.
  3. #3 Re: Still clunks after changing front sway bar end links 3 times...
    Jun 2012
    Illinois
    Not lowered at all, just a basic stocker with a couple of additions. But the clunking was there before I started putting all the new stuff on and continued until I changed the links, whereupon I got a few months of nice smooth ride until it started again.
  4. #4 Re: Still clunks after changing front sway bar end links 3 times...
    the dorman end links are crap, they dont last long, neither do the sway bar bushings.
    so maybe switch to polly end links from napa.
  5. #5 Re: Still clunks after changing front sway bar end links 3 times...
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    mine did the same exact thing! replaced everything, and still the clunk was there. Wound up replacing lower control arms, and it went away, but since youve already done those..... maybe a bad strut mount? what brand did you use?
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  6. #6 Re: Still clunks after changing front sway bar end links 3 times...
    Arizona
    Have you checked your spare tire was tightened down? And if you're strut mounts were never replaced you need to address those
  1. For Sale GXP Intake Swap parts and much more
    By DirtDog in forum For Sale - Parts
    Last Post: 11-21-2014, 08:11 AM
  2. Possible bad struts or sway bar end links?....
    By rizer in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2012, 04:54 PM
  3. Front sway bar links & outer tie rod removal problems
    By Elite6 in forum Brakes/Suspension/Chassis
    Last Post: 08-31-2012, 07:49 AM
  4. Sway Bar End Links Question
    By GPBoy00 in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 03:19 PM
