Thread: 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
Results 1 to 5 of 5
  1. #1 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
    Feb 2013
    Missouri
    So I was sway bar hunting at junkyards today (picked up a Dorman Front with bushings for $22), and bumped into a fellow member on this board, and he recommended something for my rear sway bar. The yard had a 1995 Z34 Monte Carlo, and the rear sway bar is 22MM (checked it with my caliper). Ironically, there was a 97-03 GP GT right next to the Monte, so we pulled the bar off, and held it up to the GP, and it looks like it might actually work. So I picked it up, along with all the hardware holding it to the car, hoping this will be a good upgrade and I don't need to buy end links. Anyone ever done this before or have any input on it?
  2. #2 Re: 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
    Dec 2012
    troll land
    Guess no ones thought to try it before, lol.
  3. #3 Re: 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
    Dec 2012
    troll land
    Make sure to mount it to the struts first. The ONLY potential possible issue is width, should b ok though
  4. #4 Re: 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
    Feb 2013
    Missouri
    I'm gonna mount the struts first, then mock up the brackets, move the sway bar by hand a bit to check for clearances, then drill out the 2 side holes and bolt the bracket down. Then I'll take it to a shop I live by and have them weld the bottom tab of the bracket. I think that should work, as long as I have all the clearances and such.
  5. #5 Re: 95 Monte Carlo Z34 Rear Sway Bar in 00 GTP
    Feb 2013
    Missouri
    Not happening, the bar isn't wide enough. It won't reach from strut to strut, so it's a no go. Now I'm on the hunt for a local GMPP bar again.
  1. Monte Carlo SS?
    By REDCRAPGP in forum General Grand Prix Discussion
    Last Post: 10-24-2013, 10:34 AM
  2. 05 monte carlo rack to 97 monte carlo
    By l67ss in forum Brakes/Suspension/Chassis
    Last Post: 12-23-2012, 12:16 AM
  3. rear wheel drive monte carlo
    By nemesis in forum Off Topic Discussion
    Last Post: 11-13-2009, 10:53 PM
  4. monte carlo/impala sway bars vs grand prix
    By nemesis in forum Brakes/Suspension/Chassis
    Last Post: 11-07-2008, 10:34 PM
