Basically look everything over if you can first, things like LCA's(for the bushings and ball joints), tie rod ends, wheel bearings if you have an abs or noise issue. Trailing arms for the rear are possible, they rust and can get bent.
Like I said before, you will be happiest with moog front sway bar links. You can keep the dorman ones around for someone else's car lol. Someone that doesn't care to have an improved handling.
