^^^ This or if you have a smaller pump jack like I do, I usually go for the 2 rear subframe bushing points to jack on and then once its up I put the stand under the frame in the middle (in between the lower control arms) where its solid.
On the rear I jack up on the pinch welds and put the stands under the "frame" looking section under where the rear seats would be. Once its up you'd see what I'm referring to.
Depending on the year the big square subframe is steel or aluminum but its strong enough to hold up the whole front end so anywhere on it is basically safe. Just make sure its solid and secure before you crawl under it.
