All the pressure of the weight of the car is on the Lower Control Arms. Strut to Knuckle which sits on the Lower Control Arm, which is then bolted to the frame... how can you say its not load carrying???
Now if you were using light weight aluminum racing LCAs I wouldn't lift from them, but the factory ones should hold just fine.
That is incorrect. The weight goes from the strut, to the knuckle, to the wheel bearing, to the wheel to the ground. The LCA is there for alignment and to keep the wheel in place. It's a hollow control arm.
2006 Grand Prix GT S/C 109k - Modded Transgo Shift Kit, Gutted Airbox, Dash Cam, and Inlays. Retros soon to come. 2002 Grand Prix GT N/A 127k - Same as 06 Plus: Trans Cooler, DIY Aux Input, LED lighting, Suspension Upgrades, Tint, Retrofits. Sold.
