Thread: Control arm Question
Results 1 to 17 of 17
  1. #1 Control arm Question
    Canada
    Hi guys ...I'm looking to buy 2 control arms with ball joint included for a 2005 gt....My question is they have 2 listings one with a 20 mm stabilizer and one with a 24mm bar. Are there any difference in size of the control arm...distance between bushings etc? or is the only difference just the extra lug and hole for the link kit with the 24 mm bar?
    any help greatly appreciated
  2. #2 Re: Control arm Question
    you mean end links for the sway bar? or lower control arms?
  3. #3 Re: Control arm Question
    Canada
    My lower control arms do not have a end links bolted to them( i have a 20mm sway bar)...in my understanding the 24mm sway bar have the end links bolted to the control arm....My question is can I use the control arms made for the end links?
  4. #4 Re: Control arm Question
    correct the 04+ the sway bar end links mounted to the strut, the 97-03 bolt the end links bolt to the lower control arm.
    you can use the 97=03 lca's and the 97-03 sway bar on your 04+ car
  5. #5 Re: Control arm Question
    Canada
  6. #6 Re: Control arm Question
    Canada
    So just confirming both control arms will fit an 2005 ? without having to use the sway bar as well .
  7. #7 Re: Control arm Question
    yes they fit either year car. but the idea of using the 97 -03 lca's is so you can use its sway bar.
    the top link, this one is a 04+
    bottom link, this one is the 97-03 it has a perch on the side for the sway bar end link
  8. #8 Re: Control arm Question
    Get the second one. 04-05 and some 06 have the sway bar connect to the strut. 97-03 and most 06-08 have it on the lca. Just get the one that connects to the lca so that way you can upgrade your sway bar if you want sometime down the line.
  9. #9 Re: Control arm Question
    GTX Level Member blackflag's Avatar
    Virginia
    good info!
  10. #10 Re: Control arm Question
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    I would find a Comp G front bar because they are, from what I've read, solid and 3mm thicker than stock. Plus you don't have to change control arm styles and sway bars are 40% less efficient when connected to the control arm vs strut
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  11. #11 Re: Control arm Question
    I swapped my comp g to a speedbuilt sway connected to the lca and it made a huge difference in handling. I'm thinking the comp g has the same as any other gp.
  12. #12 Re: Control arm Question
    Spring Lake, Mi
    The comp g has different bars. And that speedbuilt bar is a giant 38mm bar. It makes up for any losses from connecting to the lca. And you shelled out the money for it, so you may have a bias
  13. #13 Re: Control arm Question
    I didn't shell any money out I got front and rear sway bars with poly bushings and end links for $35
  14. #14 Re: Control arm Question
    Quote Originally Posted by Jakescoots View Post
    Throwing this figure out of your ass? Links us plz
    04 Comp G.
  15. #15 Re: Control arm Question
    Arizona
    Its true the longer the linkage the more leverage placed one a given side. The 04+ and Gxp strut endlinks require less bar and still get the same or better handling than 5 inch link connected the control arm which requires a bigger bar to achieve the same result.
  16. #16 Re: Control arm Question
    Spring Lake, Mi
    http://forums.bimmerforums.com/forum...vs-control-arm
    so if we do some math. 32mm lca mount=19.2mm strut mount
  17. #17 Re: Control arm Question
    Canada
    Thx everyone for your help
  1. A/C dual control question
    By 02 GP GT in forum General Tech Discussion
    Last Post: 05-21-2013, 07:27 PM
  2. Cruise control question
    By Cobras 98 Prix in forum General Tech Discussion
    Last Post: 07-20-2011, 03:04 PM
  3. Lower control arm question
    By DarkPassNger in forum Brakes/Suspension/Chassis
    Last Post: 06-05-2011, 11:20 AM
  4. a/c control question
    By timmysgtp in forum General Tech Discussion
    Last Post: 08-14-2010, 04:51 PM
  5. Blower control question
    By jschuett in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 01:37 PM
