correct the 04+ the sway bar end links mounted to the strut, the 97-03 bolt the end links bolt to the lower control arm.
you can use the 97=03 lca's and the 97-03 sway bar on your 04+ car
So just confirming both control arms will fit an 2005 ? without having to use the sway bar as well .
