Thread: Moog Poly End Links w/ GMPP Swaybar?
Results 1 to 15 of 15
  1. #1 Moog Poly End Links w/ GMPP Swaybar?
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    Wanted to know if the moog poly end links work with my front GMPP sway bar? Here is a link:
    Moog - Front Poly Sway Bar End Links #MOOG-K5342
    If anyone has any input would really appreciate it, wanted to try these out
    2000 Grand Prix GT- DIY Spectre HAI, KYB GR-2 Struts, GMPP Front and Rear Sway Bars, GMPP Front and Rear Strut Tower Braces w/ Don Rome Brackets
    Soon to be Installed: Poly Bushings + Poly End Links- Front and Rear GMPP Sway Bars
  2. #2 Re: Moog Poly End Links w/ GMPP Swaybar?
    Nov 2011
    NY
    Yes... Or Energy Suspension Poly's
  3. #3 Re: Moog Poly End Links w/ GMPP Swaybar?
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Im running that set up and like it.
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  4. #4 Re: Moog Poly End Links w/ GMPP Swaybar?
    Trevose, PA
    Thanks a lot for the quick responses guys!
    @h0wl0ngcanitbe- Did you notice a difference between the stock and moog end links? That is, if you installed the moog end links after you installed the sway bar with the GMPP end links...
  5. #5 Re: Moog Poly End Links w/ GMPP Swaybar?
    Marysville WA
    I did a semi big suspension job so yes I did notice a difference but thats cause I did this...
    ZZP Trailing arms
    Strut/spring combo from ZZP
    GMPP front and rear sways, and Moog bushings
    So it made quite the difference, but from what I hear the Moog endlinks are considerably better then the stock ones but I couldnt tell ya with any certainty. What I will say is they do work together well.
  6. #6 Re: Moog Poly End Links w/ GMPP Swaybar?
    Dec 2008
    Lawndale, CA
    I just changed mine to moogs with the gmpp bar. FYI they are way cheaper on rockauto than zzp.
  7. #7 Re: Moog Poly End Links w/ GMPP Swaybar?
    Trevose, PA
    Thanks for the heads up about rock auto Guz
    Anyone have any suggestions on the rear links?
    Will probably end up going with Moog part# K6662 they are $15.58 a side from rock auto
  8. #8 Re: Moog Poly End Links w/ GMPP Swaybar?
    Dec 2008
    Lawndale, CA
    Moogs in the rears are great replacements. They are recommended.
  9. #9 Re: Moog Poly End Links w/ GMPP Swaybar?
    Trevose, PA
    Anyone happen to have any recommendations for poly front and rear sway bar bushings?
    Have seen energy suspension bushings but wasn't sure on what bushings would work with the gmpp bars..
    Any links or info would be great, I know the front GMPP bar is 34mm while the rear is 19mm.
  10. #10 Re: Moog Poly End Links w/ GMPP Swaybar?
    Dec 2008
    Lawndale, CA
    I just replaced my front GMPP bushings with moogs. They are a hard almost plastic type material. They are much stiffer than the rubber ones that come with the bar. I went with moog K80815. I left the rears as rubber as I was not able to find a similar type of bushing.
  11. #11 Re: Moog Poly End Links w/ GMPP Swaybar?
    If you look up my Regal build.. I used ES bushings and endlinks on the front and bushings on the rear with Moog endlinks in the rear. GMPP bars. Pictures and part numbers should all be in there. If not.. hit my photobucket and under Regal Mods..all the pics are there.
  12. #12 Re: Moog Poly End Links w/ GMPP Swaybar?
    Heck..I was still in PB from earlier
  13. #13 Re: Moog Poly End Links w/ GMPP Swaybar?
    Pennsylvania, USA
    I used a GMPP rear bar and front Dorman and it was pretty nice, but I got poly bushings and endlinks this month and it was a MASSIVE difference. I used the same end links and bushings Bill just cited^
  14. #14 Re: Moog Poly End Links w/ GMPP Swaybar?
    Dec 2008
    Lawndale, CA
    Thanks for the pics. My brother ordered these for his 03 for his GMPP bars.
  15. #15 Re: Moog Poly End Links w/ GMPP Swaybar?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey I just got the 19mm es bushings and the gmpp rear sway bar. The es bushing fit a little loose it seems. Is that normal?
    Sent from my LG-H901 using Tapatalk
  1. Moog sway bar links
    By A70Runner in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2012, 09:02 PM
  2. Dorman vs. GMPP swaybar?
    By Mjcanton in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2011, 10:50 PM
  3. MOOG Sway Bar end links
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 06:24 PM
  4. Poly Mid mounts 4 GMPP Sways
    By black.gtp in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 07:29 PM
