Wanted to know if the moog poly end links work with my front GMPP sway bar? Here is a link:
Moog - Front Poly Sway Bar End Links #MOOG-K5342
If anyone has any input would really appreciate it, wanted to try these out
Yes... Or Energy Suspension Poly's
Im running that set up and like it.
Thanks a lot for the quick responses guys!
@h0wl0ngcanitbe- Did you notice a difference between the stock and moog end links? That is, if you installed the moog end links after you installed the sway bar with the GMPP end links...
I did a semi big suspension job so yes I did notice a difference but thats cause I did this...
ZZP Trailing arms
Strut/spring combo from ZZP
GMPP front and rear sways, and Moog bushings
So it made quite the difference, but from what I hear the Moog endlinks are considerably better then the stock ones but I couldnt tell ya with any certainty. What I will say is they do work together well.
I just changed mine to moogs with the gmpp bar. FYI they are way cheaper on rockauto than zzp.
Thanks for the heads up about rock auto Guz
Anyone have any suggestions on the rear links?
Will probably end up going with Moog part# K6662 they are $15.58 a side from rock auto
Moogs in the rears are great replacements. They are recommended.
Anyone happen to have any recommendations for poly front and rear sway bar bushings?
Have seen energy suspension bushings but wasn't sure on what bushings would work with the gmpp bars..
Any links or info would be great, I know the front GMPP bar is 34mm while the rear is 19mm.
I just replaced my front GMPP bushings with moogs. They are a hard almost plastic type material. They are much stiffer than the rubber ones that come with the bar. I went with moog K80815. I left the rears as rubber as I was not able to find a similar type of bushing.
If you look up my Regal build.. I used ES bushings and endlinks on the front and bushings on the rear with Moog endlinks in the rear. GMPP bars. Pictures and part numbers should all be in there. If not.. hit my photobucket and under Regal Mods..all the pics are there.
I used a GMPP rear bar and front Dorman and it was pretty nice, but I got poly bushings and endlinks this month and it was a MASSIVE difference. I used the same end links and bushings Bill just cited^
