Thread: AWESOME SSEi ABS Problem
Results 1 to 8 of 8
  1. #1 AWESOME SSEi ABS Problem
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    I've been really busy lately (or lazy), and haven't really checked into this. My 01 SSEi is being awesome and throwing ABS/TC lights. I haven't yet checked it with HPTuners to see the codes or whatever. Would these tell me which corner caused the issue? Basically I'm assuming its a wheel bearing sensor?
    What happens:
    Drive for a bit > hit brakes anytime > abs engages > DIC throws error "Service Stability System"
    So basically,
    Will HPTuners give me a different code for each corner? Or how do I go about determining which one to replace?
    Thanks
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  2. #2 Re: AWESOME SSEi ABS Problem
    could be the abs module, if the abs is just kicking in for no reason. the code will lead you your problem tho.
  3. #3 Re: AWESOME SSEi ABS Problem
    Pennsylvania
    I'd be interesting in seeing if HPT reads abs codes. Try it.
  4. #4 Re: AWESOME SSEi ABS Problem
    Apr 2009
    Cresco, Iowa
    I guess I will give it a shot when I get off work today.
  5. #5 Re: AWESOME SSEi ABS Problem
    I have an otc 9450 and it read certain cars abs codes it's pretty nice and was only $80 on amazon.
  6. #6 Re: AWESOME SSEi ABS Problem
    HPT should tell you on the Bonne. It tells me on the 00+ Regal.
  7. #7 Re: AWESOME SSEi ABS Problem
    GTP Level Member
    Pittsburgh
    HPT will tell you ABS stuff on the 00+ Bonneville
    2003 SSEi,
  8. #8 Re: AWESOME SSEi ABS Problem
    Bonneville/Regal FTW
  1. 01 bonneville ssei
    By GetYourShineBox in forum Members Rides
    Last Post: 05-04-2013, 08:00 AM
  2. Awesome shed is awesome.
    By I800C0LLECT in forum Off Topic Discussion
    Last Post: 04-16-2013, 01:04 AM
  3. ssei not gp but hey
    By novascotiassei in forum Introductions/Noob Questions
    Last Post: 10-10-2010, 08:16 PM
  4. GTP or SSEI?
    By KawaFord in forum Off Topic Discussion
    Last Post: 01-05-2010, 11:33 PM
  5. ssei vs gtp
    By chad27 in forum Off Topic Discussion
    Last Post: 05-13-2009, 08:57 AM
