Thread: Proportioning valve upgrade
Results 1 to 20 of 22
  1. #1 Proportioning valve upgrade
    Feb 2010
    TN
    Car is 1997 GP/GT
    Ok guys plan on doing the fbody swap up front and gxps in rear. I hear with the setup if you dig in the brakes it gets a bit unruly so someone suggested swapping out the proportioning valve with one from a 05 GXP and it would solve this any ideas? is it worth it?
  2. #2 Re: Proportioning valve upgrade
    Unruly how? Sorry I don't have any info for you, but I'm all for learning more!
  3. #3 Re: Proportioning valve upgrade
    Feb 2010
    TN
    Two people told me they suddenly lock up before the fronts
  4. #4 Re: Proportioning valve upgrade
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by Logan541 View Post
    It's not true
    I run that setup on both my cars. Never had them lock in the rear before the fronts..
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  5. #5 Re: Proportioning valve upgrade
    Ahhh.. I was told that about doing the Fbodies w/o upgrading the backs. If you get too much front end dip and rear end lift..it'll happen.
    I'm in to see if it helps.
  6. #6 Re: Proportioning valve upgrade
    I live here. TLSheff's Avatar
    Joy, something else to add to the list of things for my brake upgrade.
  7. #7 Re: Proportioning valve upgrade
    Feb 2010
    TN
    Glad I could help
  8. #8 Re: Proportioning valve upgrade
    Sheffy! Get some part numbers on this stuff, will ya?
  9. #9 Re: Proportioning valve upgrade
    Not sure what the various amounts of part numbers will do without some direction.
    Looking into the brake setups between my 99 and the 05s GXP and Non, there are no "proportioning valves" on the rear lines like ours. I believe its all done from the actual Brake Pressure Modulator Valve under the hood. Which being electronic with its own pressure sensor, will likely require a sensor change being added as I cannot find a sensor for the older body styles.
    Was Logan meaning a whole new Modulator Valve, or the actual proportioning valves on the rear lines?
  10. #10 Re: Proportioning valve upgrade
    Feb 2010
    TN
    Hi TL I was told the valve on the rear lines
  11. #11 Re: Proportioning valve upgrade
    Hmmm the mystery grows!
  12. #12 Re: Proportioning valve upgrade
    Feb 2010
    TN
    So I am guessing this is a dead mod huh?
  13. #13 Re: Proportioning valve upgrade
    Not quite yet. I still have some researching to do, just got busy at work and didn't get back to checking but I will when I can on Monday.
    I spent a good amount of time looking over the options on the GXP and Non-GXP options on the 05 models and didn't get anything positive but still think it could be in another year model.
  14. #14 Re: Proportioning valve upgrade
    Feb 2010
    TN
    Cool
  15. #15 Re: Proportioning valve upgrade
    Ok, I'm out of places to go. Need to go back to the drawing board and/or talk to the guy who suggested it, make sure he was right about the car. 04+ as best as I can show on my catalog or find on Google does not use a Proportioning Valve on the brakes. I would guess that with the updates in technology, the Electronic Brake Control Module and Modulator Valve does its job well enough the need for the Proportioning Valves was no longer needed.
    I even ran the part number for our body styles 98-03 and it didn't go much further than 03 across the board with Regals, Monte Carlos, etc...
  16. #16 Re: Proportioning valve upgrade
    I haven't had the issue either. I did have one person tell me to be careful of it happening.
  17. #17 Re: Proportioning valve upgrade
    ABS applies to the rear too on our cars right?
    I would think something wrong with it if the rears are locking up, even after that kind of a brake upgrade.
  18. #18 Re: Proportioning valve upgrade
    So Sheffer the 04+ may or may not have rear ABS.
    Yes though..the rears in my year have abs and the theory/warning I got was that the front drops enough that the rear comes up and doesn't get grip. I think the only issue would be when turning and hammering the brakes.
  19. #19 Re: Proportioning valve upgrade
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    My 98 car has rear prop valves, they are the fat round things that are inline with the rear brake lines. On my car they are about 6inches in from where the metal lines connect to the brake hoses in the back. fat round aluminum about 3" long. Those may be what you were hearing about. Not sure if they continued to use them through the entire year range of our cars. I will check at work tomorrow and see if I can get some part numbers for those and what years cover what. AND if there is a different part# for the gxp.
  20. #20 Re: Proportioning valve upgrade
    Lorain, OH
    GXP's don't use the prop valves, it is all done through the BPMV (abs valve) so guess that is a no go there.
  1. Stock intake valve versus 1.9 intake valve...worth it?!
    By slimguns in forum General Tech Discussion
    Last Post: 03-30-2013, 05:18 PM
  2. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  3. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  4. Leaking hydraulics - proportioning valve
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 10-20-2011, 01:51 PM
  5. proportioning valve replacement
    By Spartanzz in forum Brakes/Suspension/Chassis
    Last Post: 07-18-2011, 11:08 AM
