Thread: ABS and Trac Off light on
Results 1 to 20 of 22
  1. #1 ABS and Trac Off light on
    Apr 2013
    Michigan
    Im sure theres already a thread for this but Im new to the forum and figured Id ask anyhow lol Ive got a 97 grand prix gt and this morning my abs and trac off light came on and im curious as to why and what kind of money im looking at? and if it will effect my braking until i have it fixed. I dont know much about cars so yeah theres that haha thanks
  2. #2 Re: ABS and Trac Off light on
    Apr 2012
    Goderich, Ontario
    Probably a wheel bearing or the wires/ connector for the ABS (beside wheel bearing) are corroded. Easy fix.
    -Paul Walker
  3. #3 Re: ABS and Trac Off light on
    St. Louis
    Your ABS may not work, and you're looking at about $110 or so for a replacement TIMKIN hub assembly. Don't use the cheap Autozone ones. Check Rock Auto for it. Jack up the front end and put your hands on each tire at 12 and 6 and rock it in and out. If you feel play in that tire then that's the hub I'd start with. Can be replaced with basic handtools and a breaker bar. You will need a large socket for the spindle nut.
    I would check the harness first, and then go with the bearing replacement. Mine had this issue and wasn't found until I stuck a multmeter on it and discovered it wasn't getting a signal back to the EBCM.
  4. #4 Re: ABS and Trac Off light on
    Apr 2012
    Goderich, Ontario
    36mm I think.
    -Paul Walker
  5. #5 Re: ABS and Trac Off light on
    Apr 2012
    Goderich, Ontario
    -Paul Walker
  6. #6 Re: ABS and Trac Off light on
    St. Louis
    Could be. I've also seen 34 and 32 depending on what brand replacement axle has been installed in the past.
  7. #7 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    thanks, im just worried about driving it for now because as of right now i dont have the money to replace anything probably for a few weeks, would i be alright going about 3 weeks without fixing it?
  8. #8 Re: ABS and Trac Off light on
    Jan 2009
    Tallahassee, FL
    If it's just the wiring that's effed up you can drive that car till the wheels fall off.
    (the wiring won't make the wheel fall off lol)
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  9. #9 Re: ABS and Trac Off light on
    Apr 2012
    Goderich, Ontario
    If you drive it till a wheel falls off then you know it was a wheel bearing haha.
    -Paul Walker
  10. #10 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    hahhahha
  11. #11 Re: ABS and Trac Off light on
    first off look to see whats wrong then determinate if its a hub or not.
    jack the car up, one wheel at a time, leave the lugs tight. then grab the top and bottom of the tire, do a push pull with each hand. watch the rotor where it meets the caliper, if its moving you see it there.
    just tested my d/s front today, its moving a lot now. it used to just have a 1/8 inch nudge in movement.
    if the hubs feel tight, then take each tire off and unplug each hub, all 4, clean the plugs, di electrical grease them, work them off and on a few times. also check the wires to that plug, as they cant get damaged.
    this is all free to look at and figure out what maybe wrong.
    if all of this seems good, go have the cars scanned as you just wind up tossing money at it. dont know what year you got, but some newer cars will show a abs code on the free scanner at AZ. older cars need a shop to scan it, and they will charge you most of the time.
  12. #12 Re: ABS and Trac Off light on
    Banned
    Jan 2013
    Colorado
    If the lights stay on for a bit then go off while driving what would you think that is?
  13. #13 Re: ABS and Trac Off light on
    Apr 2012
    Goderich, Ontario
    This.
    -Paul Walker
  14. #14 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    now i started to get a grinding type noise near the brake pedal when coming to a stop. doesnt happen everytime but did hear it a few times. any ideas?
  15. #15 Re: ABS and Trac Off light on
    no brake pads left? look at the rotors, are they all grooved up?
    or the hub has gone to crap real bad.
    test the hubs yet?
  16. #16 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    not sure i havent checked anything yet, the car still stops fine so im not sure whats going on
  17. #17 Re: ABS and Trac Off light on
    was there a squealing before the grinding? if so, you just bought new brakes.
    if the rotors are all messed up looking, stop driving it asap. one will look like its been metal on metal. aka not nice and smooth looking.
  18. #18 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    no i dont think i heard any squeal. It was like a grinding/rattling noise that you could hear and kind of feel in the pedal
  19. #19 Re: ABS and Trac Off light on
    if you feel it in the brake pedal, check your rotors asap. metal to metal stops you for only so long.
  20. #20 Re: ABS and Trac Off light on
    Apr 2013
    Michigan
    could that be the reason my abs/trac off lights are on? or just another problem on top of that?
  1. Abs and trac light came on
    By Bluemagic in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2011, 12:08 AM
  2. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  3. abs and trac off light
    By mbuchan2 in forum Introductions/Noob Questions
    Last Post: 03-31-2011, 01:54 PM
  4. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
