Usually the problem with most aftermarket axles out there is they over pack them with grease, eventually leading to grease all up in your sub frame.
Get an axle boot band tool, repack the bearing with just enough grease to lube it and re-seal the axle band. If you over do it, the band may pop off again.
Sent from my DROID4 using Tapatalk 2
