Re: What lowering springs for best ride, and no alignment/camber issues - 2006 GP GT
comatoast
that still wasnt the answer I was looking for.. I know you need alignments after certain ( yet most ) suspension /drivetrain mods or issues... I was just trying to fint out if a certain spring or kit lowered the car without having major issues or weird camber readings
ALL lowering springs will affect camber. What do you consider "weird camber readings"?
I don't understand this. You are changing the stance of the car so camber readings will obviously change as well as how the engine sits and all. There are things that will change when you swap out suspension parts as was previously mentioned but you take it into an alignment shop, and they will make it so the car rides like factory with whatever springs you have. I'm lowered on SSC and mine went pretty damn low, a 2" drop, and I have no un even tire wear or anything.
tl;dr- your car wont explode, lower it.
Chris BadAss
x2
I guess he doesn't get it. You might get away without camber bolts but you need a alignment no matter what after there installed.
