Thread: Tried to scan with GM TECH 2
Results 1 to 7 of 7
  1. #1 Tried to scan with GM TECH 2
    GT Level Member Peacher213's Avatar
    STL Metro Area
    So my 99 gtp has the abs/tcs light currently on. I took the car to class tonight and the automotive instructor attempted to scan it with a GM TECH 2. It had a code that we cleared for the wheel speed sensor. (fixed broken wire) When he tried to run the test on the abs/tcs the scanner would say "Release Brake Pedal" This is all I was able to find out about my car.. He thinks the EBCM is bad. My only concern is that today, I left for work and the abs primed and the ABS light went out. On my way home from work both lights went out and everything was good. After restarting the car the lights are back on. I'd really like some input.. One instructor thinks it may be a brake switch and the other says EBCM. Im very frustrated right now and would really appreciate some help..
    99 GTP coupe
    Stock, other than open cone filter.
  2. #2 Re: Tried to scan with GM TECH 2
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Your ebcm is bad , try ModuleMaster rebuilds ABS modules for as low as $100, 2 day average turn-around, 5 Year Guarantee . My ebcm on my 05 went bad and got it fix through them.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: Tried to scan with GM TECH 2
    If you think it's an ebtm or brake switch, do the diagnostics. Crawl your butt under the dash and test the switch, it's so damn simple we'd make Brandon do it on his car. Then check the damn codes again. If you have wheel speed sensor again, replace the hub cause your wires may be faulty or have pulled out.
  4. #4 Re: Tried to scan with GM TECH 2
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    if ya got broken wires... im sure their still broken... and prob making good connection in one case.. and coming loose in another.. just replace hub
    .. or ignore the light
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: Tried to scan with GM TECH 2
    STL Metro Area
    Bad EBCM...Works when cold but when engine bay warms up the lights come back on, and I lose my cruise control. (The only reason I care to fix the problem)
    99 GTP coupe
  6. #6 Re: Tried to scan with GM TECH 2
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    I have a similar problem but my tics light comes and goes and my abs light stays on
  7. #7 Re: Tried to scan with GM TECH 2
    Yoga city
    yeah kinda same deal with my car man, when cold its great then once it warms up throws codes, i get a code for gm high speed lan circuit low, but wires seem to ohm out fine.
  1. 04 GTP From MA. GM Tech.
    By Ricky Bobby in forum Introductions/Noob Questions
    Last Post: 04-28-2012, 06:11 PM
  2. Gm tech 2
    By 04intimidatorSS in forum General Tech Discussion
    Last Post: 03-30-2010, 07:08 PM
  3. 2 tech questions
    By mxthunder in forum General Tech Discussion
    Last Post: 10-24-2009, 01:56 PM
  4. Meguiars Tech Wax Ftw
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 08-16-2009, 07:56 AM
