Thread: pop in front end when accelerating or stepping on the brakes
Results 1 to 6 of 6
  1. #1 pop in front end when accelerating or stepping on the brakes
    Jul 2010
    Philly
    Where should I start my search to fix this?
  2. #2 Re: pop in front end when accelerating or stepping on the brakes
    Never Never Land
    What have you already checked/replaced? Year, model?
    Id start by checking to see if your sway bar is broken as that's the easiest to check. And it's free. I'd move to ball joints after that if the sway checks out okay.
    Could be LCA bushings as well.
    Could also be subframe bushings.
  3. #3 Re: pop in front end when accelerating or stepping on the brakes
    Jul 2010
    Philly
    03 GT, haven't done anything besides see if there was play in the tire, I didn't feel any...
  4. #4 Re: pop in front end when accelerating or stepping on the brakes
    GTP Level Member buickman104's Avatar
    NYC
    Probably a shot cv joint on an axle.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: pop in front end when accelerating or stepping on the brakes
    GTP Level Member joe0813's Avatar
    Boston, MA
    id check the front subframe bushings or the control arm bushings.... i just did my control arms because the bushing on it slid down and the metal on the control arm was smashing around
  6. #6 Re: pop in front end when accelerating or stepping on the brakes
    Nov 2010
    Ray MI
    Motor mount? I had a really worn motor mount that gave me clunking when accelerating and braking.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  1. Rear End Stepping Out
    By Me5ican in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2014, 05:09 PM
  2. 07 GXP Front Brakes
    By Fireof59 in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 05:14 PM
  3. Front brakes
    By MikeB91 in forum Brakes/Suspension/Chassis
    Last Post: 05-20-2010, 07:48 PM
  4. ls1 brakes up front
    By stanggreg90 in forum Brakes/Suspension/Chassis
    Last Post: 04-12-2010, 12:32 PM
  5. Knocking from front end only when accelerating
    By Gonk24 in forum Brakes/Suspension/Chassis
    Last Post: 12-30-2009, 07:58 AM
