Thread: Brakes screeching
Results 1 to 12 of 12
  1. #1 Brakes screeching
    GT Level Member Steven Monteith's Avatar
    May 2012
    Phoenix, AZ
    My brakes have been screeching pretty bad lately and it seems its just getting worse. I have new calipers, rotors, pads, hardware. What could be causing this screeching??
  2. #2 Re: Brakes screeching
    What parts did you use?
    Did you lube things properly?
    Did you use pad goop?
  3. #3 Re: Brakes screeching
    Pennsylvania
    Ceramic pads?
  4. #4 Re: Brakes screeching
    May 2012
    Phoenix, AZ
    I used stock aftermarket stuff from a local auto parts store. Yes I lubed everything and gooped the pads.
  5. #5 Re: Brakes screeching
    GT Level Member WolvesSoulZ's Avatar
    Québec
    As silly as it may sound, did you check if the dust guard wasn't touching the rotor?
    (Pop your wheel off, look behind the rotor, if the dust guard is awfully close, bend it the other way. Mine had this screeching sound once, was the issue.)
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  6. #6 Re: Brakes screeching
    Pennsylvania
    Well, you're likely to get a little squeal if you don't use ceramic. But maybe see what's touching, if something loose, or wobbly.
  7. #7 Re: Brakes screeching
    Quote Originally Posted by Steven Monteith View Post
    Brand name please.
  8. #8 Re: Brakes screeching
    May 2012
    Phoenix, AZ
    Sad to say but I don't remember the brands. Some brands that I've never heard of.
  9. #9 Re: Brakes screeching
    Pennsylvania
    Good pick.
  10. #10 Re: Brakes screeching
    May 2012
    Phoenix, AZ
    Quote Originally Posted by SlowNA06 View Post
    Good pick.
    I know. I had a small budget at the time. I'll do a brake upgrade later on.
  11. #11 Re: Brakes screeching
    I live here. DirtDog's Avatar
    Jun 2012
    im guessing you have a grand prix...i had the same problem about a month ago...take the wheel off and in between the hub assembly and the steering knuckle there is a metal bracket that is easily bent. It holds the abs wires in place and also makes it so that the hub will come out if you need to remove it. But make sure that that piece of metal in between them is not bent and touching the rotors. Especially on the part of it thats at the bottom side of the rotor as it only has a few millimeters between it and the rotor to begin with
  12. #12 Re: Brakes screeching
    May 2012
    Phoenix, AZ
    Quote Originally Posted by marines542 View Post
    yes, I have a grand prix. Thanks I'll check for that.
  1. Loud screeching from drivers axle
    By Elite6 in forum Brakes/Suspension/Chassis
    Last Post: 09-13-2012, 01:25 PM
  2. Screeching noise from motor after header install
    By nawarkk in forum General Tech Discussion
    Last Post: 07-21-2012, 07:35 PM
  3. Loud Screeching Sound
    By Btownmills in forum General Tech Discussion
    Last Post: 05-20-2012, 07:42 PM
  4. New CV axle, Now loud screeching...
    By Greinerts in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2009, 12:58 AM
