Thread: Down to a clicking noise after replacing wheel Bearings and Tierod ends
Results 1 to 20 of 20
  1. #1 Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    My wife has a 08 Base model she had a large clucking sounds that were getting worse. Found out the tie rod ends and wheel bearing where both bad. After that is done 98% of the noise is now gone. I am just down to a clicking sound now and then. It happens when she is turning or some times over heavy bumps. For it to happen when turning she either has to be braking hard or accelerating hard. Or if there is a transition into a parking lot like a bump.
    I can get the sound out of the car in the garage. I have to get my hands on my roofline and shake the car very hard. Enough to where you can hear the fuel sloshing back and forth for while after I am done. I notice that the cars settles back fast. I did not see any oil coming from the strut when I replaced the wheel bearing.
    After I did the wheel bearings and Tie rod ends the car got an alignment and now issues where found. I would think if it is a Lower ball joint that would have been found in the alignment. When I am rocking the car the sound is coming from around the tire area. I do not think it is the top mount.
    Thank you for any help.
    My wife has a 08 Base model she had a large clucking sounds that was getting worse. Found out the tie rod ends and wheel bearing where both bad. After that is done 95% of the noise is now gone. I am just down to a clicking sound. It happens when she is turning or some times over heavy bumps. For it to happen when turning she either has to be braking hard or accelerating hard. Or if there is a transition into a parking lot like a bump.
  2. #2 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Cambridge, Ontario Canada
    CV joint perhaps especially if clicking all the time during a sharp turn.
    2005 E55 - stock
  3. #3 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    id be thinking lower control arms, i chased a clunk for some time, changed everything, it needed to be changed anyway, but the last thing i changed was the lca's and that made all the clunks go bye bye, the shops who did my alignments never said the lca's were bad.
    could also be broken sway bar ends, or bad sway bar end links.
  4. #4 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Quote Originally Posted by Elite6 View Post
    i thought about this, but how would they click when parked, and the car is being rocked?
  5. #5 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Check the sway bar end links.
  6. #6 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    True, does sound like sway bar related if noise can be duplicated in park.
    2005 E55 - stock
  7. #7 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Oct 2012
    West Springfield
    99% of the time a little click is an end link. Cheap and easy fix, good luck!
  8. #8 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Thanks.
    Sent from my SGH-I997 using Tapatalk 2
  9. #9 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Was their a change in the sway bars? I looked at the car I do not have a shaft that goes up to the strut. It bolts LCA.
    It looks like this:
    Raybestos 545-1114 Professional Grade Suspension Stabilizer Bar Link Kit : Amazon.com : Automotive
    Was this a late model change? All the autoparts stores show it should have the older style shaft.
  10. #10 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    if you search your year car and this part matches yours, it should be good to go. you can always stop at the local parts store, they are cheap enough not to order them on line.
  11. #11 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Weird part is none of the locsl parts stores online show the links that are on the car. Amazon shows both versions. Kind of weird.
  12. #12 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    97-03 are the same it changed for 04-05 then changed back in 06+
  13. #13 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Thanks. Have a harder time finding 06+ info. Most I find info for older years.
  14. #14 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Sep 2012
    St Louis Missouri
    I have the same sort of clunk. Whenving i turn right, brake, accel, or go over bumps, it will clunk. I just replaced both my LCA's and sway bar links and wheel bearings and I still get it. Im heated needless to say and don't know what else to replace.
  15. #15 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Quote Originally Posted by PioneerGTP View Post
    if the tie rods are ok, id be looking at the strut mounts.
    pop the hood start the car, then rock the wheel left and right, watch the center of the strut mount, if that bolt is moving back and fourth, you need mounts. the rubber under the bolt will look melted or beat to crap as well.
    the easiest way to change them is to buy new mounts, then shop around at a few front end shops and ask how much they charge to change them if you bring them in, in hand.
    i was charged 15 a strut to change the mounts.
  16. #16 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Sep 2012
    St Louis Missouri
    What exactly do you mean by rock the wheel?
  17. #17 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    start the car close the door with a open window, reach in grab the steering wheel and move it left to right, while doing that, watch the bolts in the strut mounts. like 10 to 2, and back, over and over. do it fast, and do it slow.
  18. #18 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Ok for me it was the end links. After replacing them I can rock the car back and forth and no sound.
    This was the drivers side that was making the noise. It was bent a little.
    Checked the passenger side. It was one piece just a little over a week ago!
    This looks so much better and the car feels better too!
    What I have replaced in the last month!
  19. #19 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    out with the old crap, in with the new.
    i dont think i ever unbolted a old end link, they always break if not already broken.
  20. #20 Re: Down to a clicking noise after replacing wheel Bearings and Tierod ends
    Northern IL
    Just checked my Mom's 07 Buick LaCross has the same end links. Think when I do her brakes in two weeks I will replace her end links while I am at it. If hers are not broken yet I bet they will be soon. Since it is bit of a drive I do not want her to have them break when I can not fix them.
  1. Clicking noise when turning wheel
    By afallucco in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2013, 10:16 PM
  2. Replacing Needle Bearings
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 05-07-2012, 08:28 AM
  3. Replacing snout bearings
    By vsl67 in forum How To Write-Ups/Tech Tips
    Last Post: 12-29-2010, 07:20 PM
  4. Clicking noise when i cut my wheel to the left or right.
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 05-24-2010, 12:30 PM
  5. Replacing bearings for SC case
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2009, 02:31 PM
