Thread: Which MOOG LCA?
Results 1 to 3 of 3
  1. #1 Which MOOG LCA?
    St. Louis
    Getting tired of the clunking in the front end and after 290K I'm sure the LCA's need to be done as I'm not sure if the prev. owner ever replaced them. I did a ball joint on the pass side a while ago but that's it.
    Want Moog LCA's, but why the huge price difference on RockAuto between the 2 "Problem Solver" LCA's? One is $79.79/side and the other is $97.79. Per the description on RA they both appear to be the same. Anyone have any knowledge on the 2 they care to share before I drop the coin?
  2. #2 Re: Which MOOG LCA?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    I think the one of them is for buicks because they use softer bushings. That's why there cheaper. Dormans are the same way.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  3. #3 Re: Which MOOG LCA?
    K80539 Front Left Lower; Problem Solver - incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Incl. bushings; Pending Supersession to CK80539
    CK80539 Front Left Lower; Problem Solver - incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Incl. bushings
    As per Federal-Mogul Resource Center - Vehicle Look-up.
    AKA Federal-Mogul catalog.
    R series is budget quality and budget warranty.
    https://www.rockauto.com/catalog/mor...733&cc=1374779
    Moog R-Series Control Arms combine quality design and construction with pricing that will appeal to budget-minded vehicle owners.
    MOOG Warranty Information
    Limited lifetime (except tools & Omega power steering products). Hub assemblies, steering dampers, and R-Series 12 months.
  1. Moog Control arms just came in
    By walkac3 in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2013, 02:23 PM
  2. Moog strut assy?
    By Wadeb79 in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2012, 09:00 PM
  3. MOOG vs Autozone junk?
    By basshead42 in forum General Tech Discussion
    Last Post: 04-19-2012, 12:25 PM
  4. Moog sway bar links
    By A70Runner in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2012, 09:02 PM
  5. MOOG Sway Bar end links
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 06:24 PM
