Thread: suspension replacement questions..
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 81
  1. #1 Re: suspension replacement questions..
    you said you had your spec sheet from the first attempt at the shop right?
    post a pic of the sheet or type them out. it should say whats acceptable, and what it is right now. so you'd need a bolt that moves it as many deg's as your out or more to make it right.
  2. #2 Re: suspension replacement questions..
    Arizona
    Just order them online
    http://www.partsgeek.com/gbproducts/...FWOCQgodaFoAkg
    All you do is make your strut to knuckle holes oblong. I might have missed it but what were your suspension mods? If your not slammed all the way you should max only need 4 bolts for the whole car. Its also possible the shop didn't try to adjust the rear lateral arms
  3. #3 Re: suspension replacement questions..
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    I have no suspension mods. All stock and original.
  4. #4 Re: suspension replacement questions..
    Nov 2009
    chicago
    Front
    Left. Right
    Camber. -1.4. -1.6
    Caster. 3.6. 3.1
    Toe. .20. 0.06
    Total toe. .26
    Rear
    Camber. -1.8. -1.5
    Toe. -0.15 -0.38
    Total toe. -0.53
    No idea what any of that means..
  5. #5 Re: suspension replacement questions..
    Quote Originally Posted by andremike View Post
    Front
    Left. Right
    Camber. -1.4. -1.6
    Caster. 3.6. 3.1
    Toe. .20. 0.06
    Total toe. .26
    Rear
    Camber. -1.8. -1.5
    Toe. -0.15 -0.38
    Total toe. -0.53
    the fronts,
    specified range
    camber between -1.4 -0.4
    caster between 2.5 3.6
    toe between -0.03 0.08
    for the rears
    specified range is
    camber,between -1.4 -04
    toe between -0.03 in 0.08 in
    it looks like your out 0.4 on the rears your whole alignment is way off too.
    so as long as your car is set up with in those ranges your golden.
  6. #6 Re: suspension replacement questions..
    you dont need to oblong the holes with all camber bolt brands. but i have seen where you have too.
  7. #7 Re: suspension replacement questions..
    Nov 2009
    chicago
    Hey I'm just thinkink if ican get the bolt out and slide the new one in.... I just save myswld about 180.00 FOR 15 MINUTES OF WORK. the biggedt question is can I get the old bolts out. And which ones or does it not matter..
  8. #8 Re: suspension replacement questions..
    old bolts will come out, take the nut off, then hit the threaded end with a mallet or block of wood and a hammer so you dont mushroom the end of the bolt. dont be afraid to hit them rather hard.
  9. #9 Re: suspension replacement questions..
    Nov 2009
    chicago
    So I can get by on these bolts. And its not worth chaning the struts to fix the problem?
    Are the +\- 1deg bolt enough then?
    I hope the alighment people don't complain that I put the bolts on myself.
    Can you tell me is the top or bottowm. Or asI suggested above
  10. #10 Re: suspension replacement questions..
    missed your last part, looks like the 1 deg camber bolt would do the trick for all 4 corners. they zero out as well.
  11. #11 Re: suspension replacement questions..
    push each corner of your car down hard as far down as it will go, then let it bounce up, if it bounces 3 times then stops moving your struts are shot.
    if it stops in one bounce, or a bit more, then they are good still and those bolts are way cheaper then new quick struts.
  12. #12 Re: suspension replacement questions..
    Nov 2009
    chicago
    Ok thanks. In case you didn't see it... which bolt am I removing top or bottom? And is it different per front or rear?
    I'd order the bolts online but I would like to resolve this, this weekend. So I need to find them locally
  13. #13 Re: suspension replacement questions..
    im pretty sure you replace the top bolt, front and back.
  14. #14 Re: suspension replacement questions..
    Nov 2009
    chicago
    I don't know what I would do without you guys... thanks so much...
  15. #15 Re: suspension replacement questions..
    Nov 2009
    chicago
    Omg.. just got the car back and what a difference....when he pulled the car around I can see the diffence in the wheels. They look straight now.... the stance is noticably diffetence.. the ride seems much quieter... the new tires I put are now the right size..
  16. #16 Re: suspension replacement questions..
    thats great, glad it all worked out.
    you put the camber bolts in yourself?
  17. #17 Re: suspension replacement questions..
    Nov 2009
    chicago
    I wanted to but chickened out.. just didn't think I would have the time
    Plus I was able to get thwm to take off another 50.00
  18. #18 Re: suspension replacement questions..
    May 2016
    Northwest
    In
  19. #19 Re: suspension replacement questions..
    Sep 2015
    Cheyenne, WY
    Did you really revive a 4 year old thread with one word?!
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  20. #20 Re: suspension replacement questions..
    May 2016
    Northwest
    Quote Originally Posted by LEVELX View Post
    Yes I absolutely did on accident
  1. New GXP Owner-Questions about suspension noise?
    By sbronemann in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2012, 11:32 PM
  2. Upgrading suspension soon just a couple questions
    By SomeDudeAtHome in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2011, 04:59 PM
  3. New suspension.. some questions on which route
    By Socks in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2010, 09:53 PM
  4. suspension replacement
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 10-30-2009, 10:13 PM
  5. Replacement suspension
    By blakshukvw in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2009, 02:24 AM
