not sure on the fronts, i think you change the top one up front too, it will get the most movement in the right direction i'd think.
Just order them online
http://www.partsgeek.com/gbproducts/...FWOCQgodaFoAkg
All you do is make your strut to knuckle holes oblong. I might have missed it but what were your suspension mods? If your not slammed all the way you should max only need 4 bolts for the whole car. Its also possible the shop didn't try to adjust the rear lateral arms
Front
Left. Right
Camber. -1.4. -1.6
Caster. 3.6. 3.1
Toe. .20. 0.06
Total toe. .26
Rear
Camber. -1.8. -1.5
Toe. -0.15 -0.38
Total toe. -0.53
No idea what any of that means..
I have no suspension mods. All stock and original.
you dont need to oblong the holes with all camber bolt brands. but i have seen where you have too.
Hey I'm just thinkink if ican get the bolt out and slide the new one in.... I just save myswld about 180.00 FOR 15 MINUTES OF WORK. the biggedt question is can I get the old bolts out. And which ones or does it not matter..
the fronts,
specified range
camber between -1.4 -0.4
caster between 2.5 3.6
toe between -0.03 0.08
for the rears
specified range is
camber,between -1.4 -04
toe between -0.03 in 0.08 in
it looks like your out 0.4 on the rears your whole alignment is way off too.
so as long as your car is set up with in those ranges your golden.
So I can get by on these bolts. And its not worth chaning the struts to fix the problem?
Are the +\- 1deg bolt enough then?
I hope the alighment people don't complain that I put the bolts on myself.
Can you tell me is the top or bottowm. Or asI suggested above
push each corner of your car down hard as far down as it will go, then let it bounce up, if it bounces 3 times then stops moving your struts are shot.
if it stops in one bounce, or a bit more, then they are good still and those bolts are way cheaper then new quick struts.
missed your last part, looks like the 1 deg camber bolt would do the trick for all 4 corners. they zero out as well.
Ok thanks. In case you didn't see it... which bolt am I removing top or bottom? And is it different per front or rear?
I'd order the bolts online but I would like to resolve this, this weekend. So I need to find them locally
im pretty sure you replace the top bolt, front and back.
I don't know what I would do without you guys... thanks so much...
Omg.. just got the car back and what a difference....when he pulled the car around I can see the diffence in the wheels. They look straight now.... the stance is noticably diffetence.. the ride seems much quieter... the new tires I put are now the right size..
thats great, glad it all worked out.
you put the camber bolts in yourself?
I wanted to but chickened out.. just didn't think I would have the time
Plus I was able to get thwm to take off another 50.00
In
Did you really revive a 4 year old thread with one word?!
