yes you can and id for sure get those, what struts are you running?
The spacers are not just for vibration. I had no vibration but my axles are both shot now.
how are they shot?
trans is brand new
just to be clear with everyone i have 4 of these in the car now
KYB Strut and Coil Spring Assembly SR4002
i want to just straight swap the lowering springs over
The stock CV boots tend to split when you change stock angle that they sit at. Personally, if I was doing my suspension all over again, I would just do the CVs at the same time.
well id do the spacers at the same time
yeah for sure, i just still dont know if lowering my car is a good idea
doing anything fun to your car will make it "less reliable" performance mods, or lowering do not help the longevity of the car obviously. but they are fun so, why not right?
You can make the car handle without lowering it and without causing the increased wear on the suspension.
my car handles pretty good right now GMPP sway bars help, lowering would be 100% for looks, any performance gains would be gravy to me and lowering it wouldnt make it that unreliable im more worried about how much harder the car is going to be to jack up and scraping on things.....michigan roads/parking lots suck
spring rate difference between stock and lowering springs isn't that much.
You'd notice more from better struts.
Or coilovers.
yeah i dont wanna spend that kind of cash though, lower center of gravity would make a difference but like i said im in it for the looks my cars on stilts right now
yes, it also ruins your suspension geometry.
Bet no one told you about that.
suspension geometry? please explain?
no.
do research.
i understand the problems that occur from lowering its not a big deal i can correct for the most of it
