Thread: Lowering spring clearance question
Results 1 to 5 of 5
  1. #1 Lowering spring clearance question
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    For the longest time my suspension has needed to be changed now i have finally decided to go with it, and in the process do some lowering too. This is my first time lowering a car so I just want to check with you guys before i buy to see if im going to rub or not. I dont think i will but i want to be sure. My wheel dimensions are 225/55/17. I am probably going to go with a basic strut, like the KYB GR2's and throw on some lowering springs. I would like to get springs to lower me from 1-2 inches if possible. Would that work? Thanks guys
    (sold) 1998 GP GT- ssm90'd. ported blower and lim, zzp fuel logs, l67 inj, 103's, zzp 2.5"dp, magnaflow mufflers, zzp plog, 3.8" ssm90 pulley, eibach springs, short db's
    2002 Z28 LS1- stock for now
    2012 chevy sonic 5spd
  2. #2 Re: Lowering spring clearance question
    Donating Users
    South Deerfield, MA
    As long as your offset isn't really low, you'll be fine. GR-2's may not last long with a bigger drop.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Lowering spring clearance question
    Yea thats kind of what i heard. Any other kind of struts you would recommend? I dont want anything super expensive.
  4. #4 Re: Lowering spring clearance question
    GR2s will be fine.
    with those wheel specs it sounds like youre safe since most wheels for FWD cars are higher offset, especially at that width.
  5. #5 Re: Lowering spring clearance question
    In canada, all struts are expensive.
  1. 130lb spring question
    By 05SS45 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2009, 10:37 PM
  2. lowering question
    By dtroit36 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2009, 03:12 PM
  3. Lowering spring question.
    By 1lowcaprice in forum Brakes/Suspension/Chassis
    Last Post: 02-17-2009, 07:22 AM
