Thread: popping/light banging from rack(?) when turning either way ?
Results 1 to 20 of 20
  1. #1 popping/light banging from rack(?) when turning either way ?
    GT Level Member reesez's Avatar
    Aug 2012
    indiana
    basically like title says. when i turn regardless of speed or direction. kinda annoying. every since i replaced my bad passenger tie rod inner and outer and had it aligned it been vibrating in the wheel back and forth too. checked ball joints and bearings and they feel tight. the axles both have movement in them when pushing shaft up and down though. i will upload a video shortly of the sound. and yes i ALWAYS search before i ask a question lol. been on forums since for years lol. so any ideas?
  2. #2 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    omfg i just thought of something...... could it be a joint in steering shaft????
  3. #3 Re: popping/light banging from rack(?) when turning either way ?
    I've never heard of the u joint going bad on the intermediate shaft but it's possible. You change the inner tie rod yourself?
  4. #4 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    yessir. then took it to get aligned. its just wierd because everything feels tight in the front end except the play in the axles. but i dont feel it would make that noise sitting still and be the axles.
  5. #5 Re: popping/light banging from rack(?) when turning either way ?
    It could but usually they only make noise when moving and turning
  6. #6 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    thats what ive always seen. but it is constant when im turning the wheel sitting still as well. i dont get it. i know my rotors are crap, and i have play in my axles, but that wouldnt cause the noise i dont think
  7. #7 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
  8. #8 Re: popping/light banging from rack(?) when turning either way ?
    I couldn't hear anything on that video.
  9. #9 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    nothing at all???
  10. #10 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    ok well i think i figured it out. did some more research and found that strut brearings and mounts go bad and cause bad things. got a video.
  11. #11 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    im getting clicking from pass side and boing/banging from driver side in the video. pretty sure the spring isnt supposed to move like that. or the top mount.
  12. #12 Re: popping/light banging from rack(?) when turning either way ?
    Springs no supposed to move like that. You'll likely need new spring mounts.
  13. #13 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    might just do new struts too. pass side is stiff and driver side bounces a few times when pushing. also my pass side spring is one inch more compressed than driver side. lol.
  14. #14 Re: popping/light banging from rack(?) when turning either way ?
    Yeah you can get a complete strut assembly and it's only 5 bolts on each side and you're done.
  15. #15 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    im seeing moog complete units on rock auto????? wth??
  16. #16 Re: popping/light banging from rack(?) when turning either way ?
    those are your strut mounts all blown out. if the rest of the struts were good you can change them mounts and be on your way.
    but after what you said its time for a new pair of struts.
  17. #17 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    now just gotta figure out what im gonna get lol. might get monroe to get me by for my long work commute. kinda sounds like my coupler is bad in that video too. dont really sound as lous as it did in the video tho.....
  18. #18 Re: popping/light banging from rack(?) when turning either way ?
    I have monroes that came on the car when i got it.
  19. #19 Re: popping/light banging from rack(?) when turning either way ?
    Aug 2012
    indiana
    they feel ok
  20. #20 Re: popping/light banging from rack(?) when turning either way ?
    Not sure how old they are but it feels kinda mushy now
  1. popping noise when turning right?
    By tichota126 in forum General W body
    Last Post: 03-24-2013, 04:28 PM
  2. Popping Sounds When Turning?
    By ljmonnin12 in forum Introductions/Noob Questions
    Last Post: 05-06-2011, 09:05 AM
  3. abs light on = hard turning
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2009, 11:39 PM
  4. another popping thread....while turning
    By cmashark in forum General Tech Discussion
    Last Post: 04-02-2009, 04:46 PM
  5. popping sound when turning...?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2008, 07:49 AM
