Thread: Front sway bar links & outer tie rod removal problems
Results 1 to 20 of 21
  1. #1 Front sway bar links & outer tie rod removal problems
    Cambridge, Ontario Canada
    Got me some new LCA's & now of course the problems start
    Front sway bar link, nut removed from top and link can move side to side easily. I am beating on it downwards but no luck - is that the right method?
    Out tie rod, nut all the way to the bottom now the nut and "bolt" spin together. What do I do? Start grinding the $hit outta things?
    2005 E55 - stock
  2. #2 Re: Front sway bar links & outer tie rod removal problems
    The endlinks are easier to replace then try to save. the tierod has a spot on the bottom that a 8mm? goes on so you need an 18mm on the nut and a 8mm? on the bottom spot
  3. #3 Re: Front sway bar links & outer tie rod removal problems
    I have new endlinks, I tried the 8mm vs the 18mm but it is getting very tight. Feels like it is going to break. So if the answer is summon the powers of chuck norris & roundhouse kick everything in the wheel well I will. Plus I can't get the castle nut out because the ball joint wont drop. wtf I don't wanna roundhouse that too.
    2005 E55 - stock
  4. #4 Re: Front sway bar links & outer tie rod removal problems
    I had to cut my ball joint off. Why are you messing with the tierod? It doesn't need to come off at all.
  5. #5 Re: Front sway bar links & outer tie rod removal problems
    Because mine does need to come off, I am replacing LCA's, sway bar endlinks & outer tie rod ends.
    Did you cut between the knuckle & ball joint bottom or but the threaded part?
    2005 E55 - stock
  6. #6 Re: Front sway bar links & outer tie rod removal problems
    I cut the nut off the top. If you're replacing the tierod anyway just cut off the bottom of it. I usually just cut them off if they give me any trouble at all.
  7. #7 Re: Front sway bar links & outer tie rod removal problems
    I will use this tool instead
    2005 E55 - stock
  8. #8 Re: Front sway bar links & outer tie rod removal problems
    Is it a good idea to put antiseize on any to prevent future problems?
    2005 E55 - stock
  9. #9 Re: Front sway bar links & outer tie rod removal problems
    Couldn't hurt anything
  10. #10 Re: Front sway bar links & outer tie rod removal problems
    St. Louis
    PB Blaster FTMFW.
  11. #11 Re: Front sway bar links & outer tie rod removal problems
    You are suppose to crack the jam nut loose before you unbolt the whole tie rod from the knuckle. Then spin the tie rod off and count the turns.
    Did you do it that way?
  12. #12 Re: Front sway bar links & outer tie rod removal problems
    Not yet
    2005 E55 - stock
  13. #13 Re: Front sway bar links & outer tie rod removal problems
    I leave the jam nut on there and spin the tie rod up to it when I put it back on.
    SE Level Member Dthreap's Avatar
    ohio
    Torches are your best friend
    Sent from my ADR6400 using Tapatalk 2
  15. #15 Re: Front sway bar links & outer tie rod removal problems
    i also reuse the old jam nut, that way i just put the new tie rod back to the jam nut and tighten it. less guess work for the trip to the alignment shop. last guy said if i was any closer, he'd be out of a job lol and that was after i swapped the rack lol
  16. #16 Re: Front sway bar links & outer tie rod removal problems
    Yeah i left old one on didnt look great but it works. I cant seem to get tie rod end out of knuckle. I cut it in half but it wont pound out downwards. More cutting i guess?
    2005 E55 - stock
  17. #17 Re: Front sway bar links & outer tie rod removal problems
    once the nut is off the end that goes through the knuckle, you hit the flat spot of the knuckle with a hammer, the joint will pop.
  18. #18 Re: Front sway bar links & outer tie rod removal problems
    you have to push it up not down it's tapered
  19. #19 Re: Front sway bar links & outer tie rod removal problems
    this is how i get it done........
  20. #20 Re: Front sway bar links & outer tie rod removal problems
    Yes! I had to cut off nut then it popped out upward. Thanks guys.
    2005 E55 - stock
  1. Moog sway bar links
    By A70Runner in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2012, 09:02 PM
  2. front sway bar removal
    By indyal in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2011, 01:51 PM
  3. MOOG Sway Bar end links
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2010, 06:24 PM
  4. Sway Bar End Links Question
    By GPBoy00 in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 03:19 PM
