Thread: left rear wheel speed sensor
Results 1 to 4 of 4
  1. #1 left rear wheel speed sensor
    Jun 2012
    Golden Eagle, IL
    ok i had the car scaned last night and it come up with the speed sensor, what do i have to do to fix it??
    the car is a 04 gt
  2. #2 Re: left rear wheel speed sensor
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    You need to replace the left rear wheel hub with ABS, make sure its abs since it includes wheel sensor. Here is a link replacing 2002 Pontiac Grand Prix Problem Wheel Hub Bearings Drive Train Axles 6 Cyl Front takes about 1 hour to do this.The rear should be the same directions or just Google rear wheel hub replacement.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  3. #3 Re: left rear wheel speed sensor
    Jun 2012
    Golden Eagle, IL
    ok i was thinking that i needed to replace the whole hub, i just wanted someone to tell me the same thing
    thanks
  4. #4 Re: left rear wheel speed sensor
    Yep just pull out the drivers rear hub and swap it with a new one.
  1. Wheel Speed Sensor Wireing harness
    By packerfanjc in forum Tires & Wheels
    Last Post: 02-16-2011, 10:09 AM
  2. Left rear speed sensor replacement
    By steverichmond in forum General Tech Discussion
    Last Post: 10-25-2010, 04:46 PM
  3. input speed sensor wheel, do i need a new one when swapping gears?
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2009, 09:48 PM
