Thread: Front Strut Replacement
Results 1 to 7 of 7
  1. #1 Front Strut Replacement
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Is this all I need;
    KYB GR-2 Struts 334227
    Each $56.35 (2) $112.70
    KYB Strut boots SB127
    Each $13.22 (2) $26.44
    KYB Coil Spring Insulator - SM5437
    Each $12.88 (2) $25.76
    KYB Coil Spring Seat - KYB-SM5470
    Each $18.37 (2) $36.74
    KYB STRUT MOUNT- KYB-SM5568
    Each $27.33 (2) $54.66
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Front Strut Replacement
    Jun 2011
    Detroit, MI
    You need new coil springs or no?
    iLoveSpade
  3. #3 Re: Front Strut Replacement
    Jan 2009
    ny
    No, springs are ok.
  4. #4 Re: Front Strut Replacement
    how many miles on the springs? how do you know they are okay?
  5. #5 Re: Front Strut Replacement
    Jan 2009
    ny
    About 48K. The passenger side mount is bad, so I figure I'd change the struts as well.
  6. #6 Re: Front Strut Replacement
    Nov 2011
    NY
    Quote Originally Posted by kissmyss View Post
    Is this all I need;
    Why not just get the quick-strut... Same price as all those components and with a new coil spring. Good if you just want to replace stock, no drop, and get a decent strut. $127 at Rockauto...
    I have my 4 waiting (KYB GR-2's) to be installed (maybe today) and will lower car next year.
  7. #7 Re: Front Strut Replacement
    Jan 2009
    ny
    I have the SS and I hear the quick struts don't give the same ride quality as the Oem spring\strut combination. I hear the SS and the 9C1 share the same suspension which is different from the other models. I like the ride quality and want to stay as close to it as possible. As I understand the Gr2's will give me that, if I was into adjusting my struts I would get the AGX's
  1. Rear Strut replacement 04+?
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2011, 04:31 PM
  2. 2006 GP Strut Replacement ?
    By DC1263 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2011, 06:30 PM
  3. Strut replacement
    By chumley in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 08:59 PM
  4. 2007 Grand Prix Strut Replacement
    By uibob7 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2010, 07:30 PM
  5. Need help, strut replacement
    By rodie1200 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 08:36 PM
