Thread: Strut Nut and washer self loosened on both rear struts
Results 1 to 7 of 7
  1. #1 Strut Nut and washer self loosened on both rear struts
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Monroe Sensatrac
    SSC Springs
    ZZP Anti-Pogo
    Noticed a metal clanging sound coming from the back of my car after I took my subwoofer box out and had my back seat down. Got home climbed in the trunk and felt both washers were loose, I tighten them, go for a drive, and the sound is gone. Now when I put them together after changing the struts I made damn sure they were on tight. Has anyone else ever experienced this?
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Strut Nut and washer self loosened on both rear struts
  3. #3 Re: Strut Nut and washer self loosened on both rear struts
    Apr 2012
    Middletown DE
    happens a lot when people dont impact the top nut on.
    I did use an impact gun but I think it was just spinning the strut rod.
    1993 Oldmobile 88
  4. #4 Re: Strut Nut and washer self loosened on both rear struts
  5. #5 Re: Strut Nut and washer self loosened on both rear struts
    use a beefy impact.
  6. #6 Re: Strut Nut and washer self loosened on both rear struts
    Not allowed to use torx and a wrench?
    Regardless, red loctite?
  7. #7 Re: Strut Nut and washer self loosened on both rear struts
    Apr 2012
    Middletown DE
    Hah I did pump the trigger Not sure what happened but I just took a 21mm wrench and a 10mm socket wrench and climbed in the trunk a wrenched away, surprisingly as awkward of placement I didn't bust my hand on anything, btw no torxs on Monroe struts.
    1993 Oldmobile 88
  1. Rear strut removal ?
    By GTP in RTP in forum General Tech Discussion
    Last Post: 03-19-2012, 04:29 AM
  2. Rear Strut replacement 04+?
    By Wingsfreak9 in forum Brakes/Suspension/Chassis
    Last Post: 09-11-2011, 04:31 PM
  3. Rear strut question
    By Dude in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2011, 11:11 AM
