Thread: 2006 GXP issue with Low Brake Fluid Sensor light
Results 1 to 14 of 14
ascotell 2006 GXP issue with Low Brake... 06-23-2012, 06:38 AM
Scottydoggs Re: 2006 GXP issue with Low... 06-23-2012, 06:51 AM
ascotell Re: 2006 GXP issue with Low... 06-25-2012, 08:15 AM
Rico Re: 2006 GXP issue with Low... 06-23-2012, 06:57 AM
Scottydoggs Re: 2006 GXP issue with Low... 06-23-2012, 07:07 AM
Rico Re: 2006 GXP issue with Low... 06-23-2012, 07:32 AM
jteske88 Re: 2006 GXP issue with Low... 06-23-2012, 07:17 AM
jteske88 Re: 2006 GXP issue with Low... 06-23-2012, 07:40 AM
michaelbm Re: 2006 GXP issue with Low... 06-23-2012, 05:00 PM
Rico Re: 2006 GXP issue with Low... 06-23-2012, 05:43 PM
Scottydoggs Re: 2006 GXP issue with Low... 06-23-2012, 06:22 PM
  1. #1 2006 GXP issue with Low Brake Fluid Sensor light
    Jun 2012
    Colonia, NJ
    I have a 2006 Pontiac GP GXP. I took it on a road trip as I do not drive it that often, I then parked the car and came back to it the next day and the low brake fluid light came on. I looked and the master was full. I then a few weeks later changed the sensor and the light is still on and the DIC is still displaying low brake fluid. I then unplugged the sensor and the light and DIC notification went away. I would like to actually fix the issue instead of just having it unplugged. Any ideas?
  2. #2 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    any chance your E brake is one click on? that would turn on the BRAKE light.
    also if your pads are real low it could just be time for new brakes.
    Hasbrouck Heights, that has to be jersey. im over right next door in Hackensack.
  3. #3 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Jun 2012
    Colonia, NJ
    Yes it is near you, the E brake is not on and the pads are about 50%. I understand about the corrosion but I am not sure where to look all the plugs and wires are clean with no scuffing. I did read somewhere that a "switch" might be bad but not sure what Switch
  4. #4 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Apr 2009
    Fort Worth TX
    scottydoggs
    I think his brake fluid level sensor light is on, not brake light.
  5. #5 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    same light in my car. i drive a regal, what do i know. lol
    and he said he changed the sensor already.
    and low pads have made the low fluid light come on for others, who may or may not have been low on fluid, you know how that works. we are not there to look at it. lol
  6. #6 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Apr 2009
    Fort Worth TX
    Damn Regal owners, like you and Bill. LOL
    I think '04 and up are a little different electronically.
  7. #7 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Yoga city
    gxp=wire corrosion, check connections and wire harness
  8. #8 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Yoga city
    well when data rate use anywhere from 0-5volts a little corrosion or anything throws things off. i had brake light and all that come on because the one wire was shorting and not coming on in time.
  9. #9 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    New Brunswick
    04-08 Do use the same light for parking brake or low brake fluid. You if the parking brake is down one click you would also get dinging and parking brake on showing on the dic. I would check for corrosion as well in the wires in addition to checking brake fluid and brake pads as well. IVe seen a small fluid leak on other cars set this light off as well.
  10. #10 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by michaelbm View Post
    If you put your ebrake on does the DIC say "Low brake fluid"?
    I would be very surprised... but who knows?
  11. #11 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Quote Originally Posted by Rico View Post
    newer cars, anything is possible i guess....
  12. #12 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Jun 2012
    Colonia, NJ
  13. #13 Re: 2006 GXP issue with Low Brake Fluid Sensor light
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by ascotell View Post
    They're probably referring to the brake fluid level switch you already replaced. It's got to be wiring.
  1. brake fluid
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2011, 04:56 PM
  2. Low Brake Fluid??
    By jezzer in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 10:12 AM
  3. Parking brake warning light on after fluid change
    By aziff in forum General Tech Discussion
    Last Post: 05-02-2011, 10:06 AM
  4. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  5. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
