Thread: ABS Problem again.
Results 1 to 7 of 7
  1. #1 ABS Problem again.
    GT Level Member ljmonnin12's Avatar
    Nov 2010
    Sidney, OH
    Just finally figured out and got everything fixed from my last ABS problem, have driven it for 4 months, now something is wrong again. This time is different though, now the lights aren't on when I turn the car on, but when I drive for a little bit and get up to about 50-65 mph (and when it's hot out) the lights kick on. I just had both front hubs replaced. Idk about this one. And ideas?
    -ljmonnin12
    -ljmonnin12
  2. #2 Re: ABS Problem again.
    figure out which wheel its coming from.
    then try doing so digging in the wire harness's to see if a wire is cracked/broke
    Nov 2010
    Sidney, OH
    I did have a wiring harness that was cracked in like 3 places, and my mechanic fixed it and I think that could be my problem. He did say it may not hold up long.
    -ljmonnin12
    -ljmonnin12
  4. #4 Re: ABS Problem again.
    id look to see how they spliced the new harness on, if they used them clip thing or even the crimp kind, they all fail over time.
    solider and shrink wrap is the only way to go about it.
    Nov 2010
    Sidney, OH
    How much would it cost to replace?
    -ljmonnin12
    -ljmonnin12
  6. #6 Re: ABS Problem again.
    id give the harness a good once over before buying a new harness. but they are under 30 i think.
    if they have it taped up, take it off and see what they got hiding under it. tape would be a bad sign.
    make sure the plugs are clean, and on tight. also a dab of di electrical grease helps make good connections.
  7. #7 Re: ABS Problem again.
    Pennsylvania
    Scan it. Same symptoms I had when my EBCM was going bad.
  1. KR problem
    By zildjian102 in forum General Tech Discussion
    Last Post: 09-18-2011, 03:09 PM
  2. HID problem
    By supercharged06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 07:37 PM
  3. HID problem
    By joshbarker in forum Visual/Body Modifications
    Last Post: 06-09-2009, 01:26 AM
  4. DIC problem
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 04:41 PM
  5. well now its a problem...
    By the1euge in forum General Tech Discussion
    Last Post: 10-26-2008, 01:43 AM
