Well the time has come to start messin with suspension stuff, so this thead is to help me keep things straight and get input/help from people on here.
Over the winter ill start gathering all the pieces for a complete overhaul
Ive read every thread on here about suspension(the sticky ones) and this is the list i came up with
The links are not where im going to buy it from just to get an idea of prices
if anyone knows a place with better prices please add some input
just about the bushings thatll be replaced will be poly also
sways-
front- http://www.amazon.com/Dorman-Solutio...vglnk-c2477-20
rear- would like to find the slp bar, but all i can find is it in a set
but if i can find the BMR/Addco/Speedbuilt/Next Level ones then ill go with that but cant seem if find any of them
UMI bars-
1997 - 2005 GM W-Body Tubular Rear Trailing Arms [3715] - $129.99 : UMI Performance, Inc.
Struts-
open to others but from what i found these seem to be the fav
KYB AGX
Shockwarehouse.com Shopping Cart2
i know ill need the other things but not sure on where and what to get
anit-pogo things
mounts
Springs-
vogtlans
Pontiac Grand Prix W-Car | 97 - 03 Sport Lowering Springs 959206
or
wbs
W Body Store
dont know which, both have the right a mount of drop i want and high spring rates but i know the wbs ones are progressing springs but other then that, is there any other benefit of these?
anyone run these?
Strut bars-
the zzp bar up front and maybe in the rear to just for the price
if not ill just go with the gm factory bar up front and the zzp in the rear
ZZPerformance - ZZP Strut Tower Braces #
Since ill also be lower the car a bit i need the find the rest of the stuff that goes with lowering
Ive read alot people say upgrade the lca's but i dont think ill need those, i dont plan on racing it
since ill be there ill replace the bushing with poly ones tho
Please input as much as possible and if anyone has any better ideas or other items i should go with please comment
I plan on keeping this thread updated as i go and also use this thread as a brake thread too since ill be swapping them out in the spring
thanks
