Thread: Replaced Oil Switch/Whining
Results 1 to 5 of 5
  1. #1 Replaced Oil Switch/Whining
    Feb 2009
    South West Lower Michigan
    I replaced my oil pressure switch last Thursday and immediately after installing, I noticed a power steering whine that was not there beforehand. I had to work around a steel line to line up the oil pressure socket to replace it. Question: is that stainless steel line in that area a part of my power steering mechanism? Thanks for any input / thoughts.
  2. #2 Re: Replaced Oil Switch/Whining
    yes it is the p/s line, and the sender you changed has nothing to do with your p/s pump whining. its time for another little project.
    unless you broke the line somehow and fluid leaked out.
  3. #3 Re: Replaced Oil Switch/Whining
    Feb 2009
    No leaks, already checked. My pump has always had a quieter whine, this is just more noticeable and LOUDER. I realize that pressure switch has nothing to do with my power steering, my question was about that line, thanks for the reply...Power steering feels great and the whine does quiet down as it warms up. Will keep a sharp eye on it.
    1997 Pontiac Grand Prix GT 3.8 N/A 160,000 Miles Dark Teal Metallic.
  4. #4 Re: Replaced Oil Switch/Whining
    you will know when its time, no more power steering, when it starts to whine bad change it as fast as you can because driving a car with a bad pump WILL KILL YOUR RACK. you dont want to do a rack unless you have to.
  5. #5 Re: Replaced Oil Switch/Whining
    Feb 2009
    Thank Scott, most definitely don't want to deal with a bad R/P.....
  1. Whining sound at 30 mph
    By NeedGTHelp in forum General Tech Discussion
    Last Post: 02-10-2011, 05:47 PM
  2. Whining Noise
    By silo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:50 AM
  3. Neutral Safety Switch replaced---Still problems
    By jokyfo in forum General Tech Discussion
    Last Post: 03-27-2009, 09:06 AM
  4. my 3.1 is whining!!!
    By 99gpse in forum General Tech Discussion
    Last Post: 12-21-2008, 12:20 PM
