Thread: Rack and Pinion Help???
Results 1 to 20 of 28
  1. #1 Rack and Pinion Help???
    GT Level Member ill12will8's Avatar
    DC/MD
    Ok so my rack and pinion took a huge dump on me last night. My steering wheel is now upside down and its quite scary to drive. I have a few questions...Is it in fact my rack? Do I have to replace it with a Magnasteer unit? What else do I need to replace it? Would anyone suggest me replacing it myself or leave it to a pro?
    1997 Artic White GTP: Stock (I call her "Brooke")
    2000 Silvermist GTP: ZZP DP, CAI w/ 9" open cone, Dorman front sway bar, PEMs, AL605 -DEAD & GONE
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    The steering rack isn't very hard to replace. But you need to be comfortable with lowering the sub frame to get to it.
    If your car originally came with magnasteer, You need to put a magna steer rack in. They're pretty much the same price anyway.
    I would suggest replacing the high pressure line, and the power steering pump while you were there.
    Sent from my DROID RAZR using Tapatalk 2
    For all your 3800 needs:
  3. #3 Re: Rack and Pinion Help???
    did you hit something or just all of a sudden the wheel skipped a few teeth and you can feel the steering box crunching.
  4. #4 Re: Rack and Pinion Help???
    DC/MD
    i hit a huge crater of a pot hole and i cant feel it crunching but the wheels are turning out very wide
  5. #5 Re: Rack and Pinion Help???
    check your whole front end out, you could have just blown out the ball joint or tie rods, inner or outer and lost your alignment.
    jack the side that you hit the hole with, and push the wheel form 9 to 3 o'clock, and see if you can feel it moving, and also 12 to 6 o'clock, for the ball joint. the lca's bushing also like to fail, while the cars on the jack look at the bushings to see if they are torn up. where the lca bolt to the sub frame.
  6. #6 Re: Rack and Pinion Help???
    DC/MD
    how do you check the tie rods?
  7. #7 Re: Rack and Pinion Help???
    by pushing and pulling at the 3 and 9 o'colck or the tire, if it moves more than say a 1/8 of a inch you'll feel the slop.
    also make sure your struts not bent. or the lca not bent as well if you really ate it when you hit the hole.
  8. #8 Re: Rack and Pinion Help???
    DC/MD
    alright thanks. but my main focus is the position the steering wheel is when the wheels are straight
  9. #9 Re: Rack and Pinion Help???
    if the the tie rods are bad or bent or anything else is worn out the steering wheel will and can be way off from straight.
  10. #10 Re: Rack and Pinion Help???
    DC/MD
    i went and jacked the car up wiggled both wheels both are fine. tie rods arent bent. so i assume its the rack
  11. #11 Re: Rack and Pinion Help???
    DC/MD
    Are the 97-03 racks compatible with the 04+
  12. #12 Re: Rack and Pinion Help???
    look up the rack for your car, then cross reference the 97-03 part #. im thinking they are different.
  13. #13 Re: Rack and Pinion Help???
    GT Level Member ls1camino's Avatar
    Laurel, MD
    How can you tell if a car has Magnasteer? I'm getting ready to replace my rack, and I don't want to tear my DD apart and find I have the wrong part.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  14. #14 Re: Rack and Pinion Help???
    you need to look at the area where the steering column meets the rack, from that area you will see 2 wires lead up to the engine, those wires from the rack mean you have magnasteer.
  15. #15 Re: Rack and Pinion Help???
    DC/MD
    Open your trunk and look for the RPO code NV7
  16. #16 Re: Rack and Pinion Help???
    DC/MD
    this rack is serious a PITA i havent even gotten it out yet took all day to get the little i got done. anyone have any tips?
  17. #17 Re: Rack and Pinion Help???
    rack is fun
    put car on jack stands, remove both wheels
    pop both tie rods off. and the sway bar end links.
    on the driver side you have the the steering box area where the steering column connects to the rack, its a 11 mm bolt, you need about 12 inches worth of extensions to get to it. lift the boot up and you will see it.
    next you want to put a jack under the back part of the sub frame, loosen the 2 frame bolts about 2 inches, then lower the jack slowly till your almost at the bolts, don't let it hang on the bolts. let the jack hold it.
    now remove the sway bar bushing bolts on both sides, you can remove the bar or slide it up out of the way.
    there are 2 power steering pump lines that bolt into the rack on the driver side/side of the steering box part. 2, 18 mm nuts. remove them. you can get to them from under the driver side of the car. have a small pail or something to catch the small amount of fluid that will come out of the lines and rack when you take these lines off.
    you now have the 2 nuts and bolts that hold the rack to the sub frame to get out.
    and now is the fun part, you want to take it out the driver side wheel well, twisting action helps some, i think it was clock wise.
    with your wheels straight the bolt for the steering gear is facing the driver side, so just lock you steering wheel and leave it locked, if you turn it round and round you WILL break the clock spring in the steering wheel.
    match up the steering gear on the new rack to the one you took out as best as you can, that way when you try to get the steering shaft back on the rack it will be close to where it was when you locked the wheel. best to have a friend twist the wheel a bit side to side as you try to get it back on the new rack, this can be about the hardest part for some people. i had no problem at all, matched the new one up and it slid on the rack.
    the thing that makes this job suck is, it's just working in tight places. it took me about 4 hours to do start to finish, like tools cleaned and put away type done.
    im sure i could do it faster should a second time happen.
  18. #18 Re: Rack and Pinion Help???
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Yeah I did about the same but disconnected the lines from the power steering pump and brought them out with the rack. it was easier to do that. and get those bolts off with the rack on a table.
  19. #19 Re: Rack and Pinion Help???
    you were able to get the lines out with the rack? first i've heard of that.
    the 2 line bolts were not even a problem to get off or on.
    the write up i followed said to remove the air box and the master cylinder, to get the lines from up top, but after looking at it i could see the lines were easily accessible from underneath the car.
  20. #20 Re: Rack and Pinion Help???
    DC/MD
    thanks for all the help scottydoggs. This was the most difficult thing ive ever done on a car. But heres a pic of the old one
    it cracked open
  1. Looking for a new rack and pinion.
    By QUICKSILVER462 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2012, 07:43 PM
  2. rack in pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 10-25-2011, 04:28 PM
  3. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  4. rack and pinion
    Last Post: 02-21-2011, 09:53 AM
  5. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
