check your whole front end out, you could have just blown out the ball joint or tie rods, inner or outer and lost your alignment.
jack the side that you hit the hole with, and push the wheel form 9 to 3 o'clock, and see if you can feel it moving, and also 12 to 6 o'clock, for the ball joint. the lca's bushing also like to fail, while the cars on the jack look at the bushings to see if they are torn up. where the lca bolt to the sub frame.
