Thread: Stiffened Suspension up... looking for suggestions!
Results 1 to 17 of 17
  1. #1 Re: Stiffened Suspension up... looking for suggestions!
    Odi, tire width won't help unless you're overheating the tire.
    In that case, you might want a better tire period.
  2. #2 Re: Stiffened Suspension up... looking for suggestions!
    Quote Originally Posted by coolone View Post
    I like the Vogtlands cause I've read the drop is not too low and not too hard. I know nothing of re-valving the struts but am willing to learn. Can you provide more info., links?...
    ClubGP Message Forum troubleshooting
    Good place to start.
    But basically the struts have to respond to movement, the rate at which they do so is called the shock rate.
    Ideally it should be set for the springs you use as well as the vehicle mass.
    Quote Originally Posted by Sandman View Post
    They're the custom built ones in stock housings but I got them used off another member a while back.
    Figured as much.
  1. Time to refresh tired suspension! Suggestions?
    By rcdino1978 in forum Brakes/Suspension/Chassis
    Last Post: 11-23-2011, 05:46 PM
  2. suspension makeover. opinions and suggestions plz.
    By gtpinsc in forum Brakes/Suspension/Chassis
    Last Post: 01-24-2011, 05:37 PM
  3. Suggestions?
    By mosley1990 in forum Visual/Body Modifications
    Last Post: 08-30-2009, 05:48 PM
  4. Suspension suggestions
    By travon802 in forum Brakes/Suspension/Chassis
    Last Post: 05-25-2009, 02:12 PM
  5. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
