Happy (almost) New Year. I have an 06 GT that I am trying to put new front controls arms on. So far I have been unable to pop the ball joint free. What tool or technique has worked for you?
I was worried that a pickle fork would gouge the aluminum. If it worked for you then I'll give it a shot. Thanks
i used a hammer and hit the side of the hub assembly next to where the ball joint goes into. I wouldnt recommend unless you know what your doing.
Try hitting it with your purse you sally. (I'm just kidding)
I use a 3lb ” siege” hammer as I like to call it with a pickle fork. Works for me.
stealing
'siege hammer"
Used a pickle fork and was able to change both control arms. Thanks for the help everyone.
Don't even own a pickle fork. Don't need one. As was mentioned by BlackGT97, hitting the knuckle with a hammer at the part where is seats on the ball joint would knock it loose.
