Thread: Just became my most pressing issue!!
Results 1 to 12 of 12
  1. #1 Just became my most pressing issue!!
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    Many of you that respond to my threads realize i am dealing with several issues.Some issues are small some may be larger,luckily the car has been running decent enough to keep me going.Well this issue started tonight and had me fairly concerned.Most noticable at moderate speed (20-30) noticed that the car started really getting bumpy/jerky when your driving straight and you slightly turn steering wheel to the right.You can correct the wheel to straight but the herky jerky bumping stays for a bit then goes away.But it is pretty rough while its bumpy.And it is not doing it everytime,some drives no issue.Ive also noticed that while driving and again slightly turning steering wheel to right(maybe left too)once you get to a certain point it feels like the steering gets stiff or kinda hits a block(if this makes any sense).Anyway since getting the car the front has gotten new tires,new outer tierods,and an ALIGNMENT.I do realize this is not much to go on and could be numerous issues,its got me sad cause im probably gonna take it to BIG ALS tomorrow.
  2. #2 Re: Just became my most pressing issue!!
    GTP Level Member
    Nov 2011
    Kansas
    Brake Rotors may be bad.
  3. #3 Re: Just became my most pressing issue!!
    Cambridge, Ontario Canada
    Better take a look under the car at the suspension & steering, make sure nothing is broken
    2005 E55 - stock
  4. #4 Re: Just became my most pressing issue!!
    Nov 2011
    portsmouth,virginia
    Well i just got back from BIG ALS.Their assessment is that it is the steering rack is starting to bind.only $500 to fix.
  5. #5 Re: Just became my most pressing issue!!
    you can get a used rack for 75 to 125 from a junk yard, or get a new one from anywhere from 200 to 300, and install it yourself, and pocket the rest of all that money to fix other problems. its not a fun job but well worth doing if on a tight budget.
  6. #6 Re: Just became my most pressing issue!!
    Nov 2011
    portsmouth,virginia
    sadly scottydoggs you are talking to the least mechanical guy i know lol.but i will look into the junk yard part.i know a few garage mechanics,maybe if im good they will let me help.
  7. #7 Re: Just became my most pressing issue!!
    that would be the way to go, that way you can learn as you go.
    its really just nuts and bolts, not a big deal, the only tools you need are a lug wrench, 11mm, 13 mm, 15mm, 17mm and a 18mm socket and 18mm line wrench or open end. 2 jack stands and a good jack.
    the link for the rack removal is dead right now, if it comes back on line, you could read through it, its not that bad.
  8. #8 Re: Just became my most pressing issue!!
    Nov 2011
    portsmouth,virginia
    scotty dude.I visit jersey at least twice a year.If i thought this car could survive a 400 ml trip at be at your front door lol.I just did an online search of steering racks,not too bad for a new one.However one question,it offers option of with magnasteer or without.Which would be appropriate?theres only a $10 dollar difference between the two.
  9. #9 Re: Just became my most pressing issue!!
    Sep 2011
    MI
    If you have magnasteer you'll have wirings coming off your rack...
  10. #10 Re: Just became my most pressing issue!!
    Nov 2011
    portsmouth,virginia
    Are these wires visible or only after you get to the rack.I need to order this part ASAP.
  11. #11 Re: Just became my most pressing issue!!
    if you can get your car up in the air, ramps or such, look where the steering shaft hooks up on the rack,(round part, with a rubber boot to the fire wall) diver side, from there will be wires leading up to the side of the trans, and thats where the plug is to unhook the racks wires. if you have magnasteer.
    most of these cars have it so chances are you do, worst comes to worst, call the dealer with your vin # in hand and they can tell you.
    or check out your rpo codes in the trunk, FE3 is sport suspension, so that's automatically magnasteer. and theres a code for magnasteer as well, not to sure maybe NV7 ??? there is a sticker on the inside of the trunk lid with the codes on it.
  12. #12 Re: Just became my most pressing issue!!
    Nov 2011
    portsmouth,virginia
    Scotty im gonna go get a picture of the sticker.Maybe you could take a look.
  1. *SOLVED* Starts fine - will not idle or run by pressing pedal
    By cptnjarhead in forum General Tech Discussion
    Last Post: 10-10-2011, 06:58 AM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. 05 issue
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 08:21 AM
  4. Pressing the pulley off
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:01 PM
  5. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
