Thread: Engine & Trans Mount Spacers
Results 1 to 7 of 7
  1. #1 Engine & Trans Mount Spacers
    May 2008
    Winnipeg, MB
    I think I could make my own Engine & Trans Mount Spacers instead of buying them. Does anybody have the dimensions so I got something to go by.
    2x3" rectangle, 1/4" thick, so far so good? how many of these do I need?
    how far apart and big do the holes need to be?
    2007 Pontiac Grand Prix
  2. #2 Re: Engine & Trans Mount Spacers
  3. #3 Re: Engine & Trans Mount Spacers
    On the motor mount side. I measured between the two bolts and noted the approximate length that would fit in the bucket. Then for the top of the mount, measure there as well. I'm assuming you need 1/2" total spacing.
  4. #4 Re: Engine & Trans Mount Spacers
    May 2008
    Winnipeg, MB
    buy a motor mount. make a template using that.
    done.
    why can't I use the existing engine and transmission mounts?
    so far I have the SSC springs and anti pogo washers
    thinking of just using my stock struts as they are still in good shape
  5. #5 Re: Engine & Trans Mount Spacers
    well you can use the existing ones if you want, but that means youll have to have the car apart to do it. buying new motor mounts gives you the ability to do it on the side and put everything together all at once.
  6. #6 Re: Engine & Trans Mount Spacers
    May 2008
    Winnipeg, MB
    How many spacers do I need?
  7. #7 Re: Engine & Trans Mount Spacers
    I needed 1/4" on top and bottom of the mount to keep it correct. 1/2" wouldn't fit on just top or just bottom for me, so I split it up.
  1. i need trans /engine mount brackets
    By merciero in forum 04+ Specifics
    Last Post: 10-14-2010, 07:39 PM
  2. engine/trans mount or suspension squeek?
    By oneil.GTP in forum General Tech Discussion
    Last Post: 09-25-2010, 07:28 PM
