Thread: Suspension Troubles
Results 1 to 17 of 17
  1. #1 Re: Suspension Troubles
    Oct 2011
    Michigan
    I replaced the front struts only because the shop that replaced the rest of the "stuff”, who by the way had originally told me the struts were "OK", changed his mind after I returned to him because the "Thunk" continued. Needless to say, I took the car to another shop for the Wheel Alignment. The Technician there also noticed the New struts in the front and the Old struts in the rear. His determination was the Rear struts were "OK" for now with no signs of leaking BUT I should think about replacing them in the future also. At this point, I'm waiting for the LCAs to arrive from the WWW.Amazon sight I bought them from for $43 ea. but I'm heading out today to Autozone for the Engine Mount. The temp is supposed to get up to 65 and sunny...perfect for driveway wrenching.
    Thank you all for your replies. What more could you ask for here than all of your Bright minds coming up with practical solutions to our sometimes problem vehicles!
  2. #2 Re: Suspension Troubles
    Oct 2011
    Michigan
    Ok...I've replaced the Engine Motor Mount like Abrasive so nicely describes here in his "How To" post http://www.grandprixforums.net/engine_mount.php
    It was Very Easy!!! Unfortunately the "Thunk" still exists when you take-off from a stop. Hopefully when the LCAs arrive and are installed they will cure the ills.
  1. HVAC troubles
    By ajramos26 in forum General Tech Discussion
    Last Post: 04-19-2011, 08:56 PM
  2. transmission troubles
    By gtpfreak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2010, 08:47 PM
  3. Top Swap Troubles??
    By Pontiacman76 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 09:39 PM
  4. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
  5. Energy Suspension Suspension Parts
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 03-09-2009, 10:25 PM
